Question about Kenmore Dishwashers
Kenmore Elite: - Stale smell from dishwasher, won't go away, lingers on dishes, glasses. I tried a vinegar remedy suggested by a diy site - it helps for a cycle or two, but the smell comes right back. Diy site suggested taking apart the dishwasher to see if there is food trapped: there always remains a little water at the end of each cycle - but I'm concerned about taking apart my dishwasher if there is another solution. Smell doesn't smell of food to me. What do you think? Hollie Smith
  • 132 Answers
Try useing your heat to dry at the end of wash,or mabey take and blow your unit out with a compressor and attatchment especially the drain outlet. also run a cycle with just a little lime away then flush with a second rinse.
Posted on Oct 13, 2010
I have a front loader kenmore and there is a stale smell on my clothes. I have run the machine with vinegar, tried bleach and now have tried tide cleaner for the washer and my clothes still smell.
try to change the rubber around the door opening this will take care on the odor also try using the afrsh washer cleaner and use a double dose 2 tablets
Sep 04, 2011 | Kenmore Elite 45986 Front Load Washer
White coating on glasses, silverware and door of dishwasher that is very difficult to remove (even with a stainless steel scrubber) Is there a product I should be running through the cycle (without...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
New Kenmore 13743. Many of the glasses come out with a white film on them. Called the local Kenmore (Marshall at 1-800-469-4663) repairman on the advice of my salesperson. He said that he has frequent...
Have you tried cleaning a single glasses with vinegar. Take a glass, soak it in vinegar for a couple hours, wipe it dry and see if the film goes away. If it does you know vinegar will work to help. I use vinegar with every wash now cause the film builds up quickly. If the film doesn't go away then it is likely that the glasses are getting etched by a corrosive detergent.
Dec 17, 2010 | Kenmore 13743 Staimless Steel Built-in...
Our dishwasher developed a musty smell. The smell
I would use bleach and then rinse and then air dry.
Nov 13, 2009 | Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes come out with a white, chalky film, not very clean.
are you using palmolive eco liquid detergent? if so - google "palmolive eco white residue" and you will find out that your detergent is the culprit. the solution is to use 1/2 cup of vinegar in your rinse cycle and soap dish and STOP USING PALMOLIVE ECO!
May 02, 2009 | Maytag MDB8551 Built-in Dishwasher
Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
Dishwashers Logo
652 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
