Question about Denon PMA-100M Amplifier
My Denon amp (model PMA-900V) has suddenly devloped a hum/buzz. Regardless of the setting/mode, there is a hum coming from the speakers. I am assuming it's the capacitors. Any other ideas? Do you know how many capacitors are in this unit? Is it easy to replace them? The repair shop I used for years (Audio Clinic in Silver Spring, Maryland) closed and I haven't found a decent repair shop yet so I am thinking of attempting the repair myself. Thanks in advance for your help. Mike Moore
  • Denon Master
  • 5,167 Answers
It won't hurt to replace the Capacitors. The ones in question will be the big ones in the power supply. They will be at least 2,000UF and more likely higher. Replacing should be simple. All you need do is unsolder them and fit new ones. Sometimes they glue them in, so if you have got rid of the solder and they wont budge, that's why! Replace them with what it says on them if you can. But you can go higher. For example if it says 2,200UF 50v you can replace it with anything above that, but nothing lower. The only other problem with none direct replacement is size. So make certain it will fit in the space. Oh make certain too you get the + (on Cap) to the + on the board (though most are marked with the - symbol, so put the - to the -). Also look out for the temperture rating of them, marked (say) 85C. Again you can fit one higher, but fitting one lower will cause it to fail quicker though it will work.
If they don't solve the problem you could be looking at something on the main amp board causing it. Remember because the hum is in both channels it has to be something common to both.
Posted on Oct 14, 2010
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
I have a Denon PMA 500V amplifier. all of the output fuses were blown so I replaced them but the unit still doesn't work. Any suggestions?
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
Thanks and good luck
microhit
Jun 01, 2011 | Denon PMA-2000R 2-Channel Amplifier
My Denon PMA-900V integrated amp has distortion in the left channel. When it is cold it is very minor, as it heats up and is played at louder volume the distortion is much worse.
The good news is that it's in one channel, which means you have the right channel parts to compare it with. Now the bad news whatever causing it and it's likely to be a semi-conductor (transistor or IC) has to be replaced. However finding it is easier than you might think. For a start it's going to be hot to touch. And you can get get it to stop being hot, while the amps on, so correcting the fault, for a while. You do this by spraying it with Servisol Super Freezer spray. You have to have the amp running for this. Find the left channel amp and wait while it goes bad. Then spray (one at a time) any part you suspect. If the sound returns to normal, you have found the faulty part! To prove it spray the same in the right channel. That shouldn't change.
You can get the freezer spray from your local electric parts shop (such as Maplin UK).
Jan 13, 2011 | Denon PMA-100M Amplifier
Hi , I have a denon pma-2000r amp in it stuck in stand by mode, i don't have original remote control, is it possible to turn it on without remote control or reset to factory settings? Many thanks!
That model shouldnt be stuck in stand-by
Are all the speakers connected?
If it wont properly turn on then there is a fault being detected. Could be disconnected speakers / bad speaker or a power supply issue
Nov 01, 2010 | Denon PMA-2000 IV R 2-Channel Amplifier
I have no sound coming from the horns in my speakers.Pretty sure its not the speakers.
Try a set of headphones and see if the high end works in those.
Also , is the treble on the amp turned way up?
Get back to me
Thanks
Oct 31, 2010 | Denon PMA-2000R 2-Channel Amplifier
The amp shuts down repeatedly after approx 3 mins of operation
Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you don't see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you don't see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then that's why the protections coming on so you don't blow out your speakers. If you don't have any equipment or don't have any electronics experience I would then take the unit to a repair person for an estimate. Good Luck
May 29, 2010 | Denon PMA-2000R 2-Channel Amplifier
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
Denon pma-520
If you understand electronics then work backwards from the speaker outputs to the imputs. You need to make the channel buzz by touching the circuit, you can use a small screwdriver. Best of all is a signal injector, you can buy one at a electrical service shop (Maplin UK) they can be cheap for a very simple one.
Compare the results with the good channel. When the sound gets weak you have located the area in which the fault lies.
If not then off to the repair shop.
Sep 16, 2008 | Audio Players & Recorders
Denon PMA-100M Amplifier Logo
576 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
