Question about Zebra TLP 2844-Z Thermal Label Printer
The printer is printing very light and we have changed the printhead to one we know is okay and the problem still exists.
  • 96 Answers
Check the darkness setting in your printer driver. (increase to darken)
Posted on Oct 13, 2010
Lanier printer
first go to start menu and select devices and printers
and select your printer then right on the icon -select printing preferences
select print quality tab and select restore defaults
disconnect/connect of the cables, the resetting on the ink cartrige, the align printer (which did fail); however, after going through all the steps a couple of time the Clean Printhead option finally cleared up your problem.
Mar 03, 2014 | Office Equipment & Supplies
Intermec PX4i printing blank labels
I found the following item on page 3 in the printhead installation manual:
"Note: If you are installing the 400 dpi printhead on the PX4i
printer (Kit P/N 850-812-900 IPL Only), you must first
update the IPL firmware to version 2.74 or later."
I assume this is a partial exception to the general caution on page 1 of the same publication:
"When installing a printhead, make sure that the printhead
density and alignment is the same as in the one you replace
and that the printhead is designed for the type of printer in
which you are going to install it."
Also, the printer should not be powered when the printhead is being installed. The printer does not identify the printhead until it goes through a power-on startup.
Feb 27, 2012 | Intermec PX4I Label Printer
Will not print in black. Colour okay. Have
There's a couple of things, the printheads wear out and need replacing now and then which is probably your problem, also there's an update to the printers firmware available to Canon service centers which helps the purge assembly clean the black even better. The printhead is QY6-0052-000 aprox. $50.00.
Dec 30, 2009 | Canon PIXMA iP90 Mobile Printer
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Too much green
Hold the print head over a steaming kettle take care not to scald yourself. The ink will run out of the bottom of the printhead just dab on a piece of paper towel, when you see green you will have cleaned it. I dont know if this will do any long term damage to printhead but it has worked three times for me
Apr 04, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
NOt printing text
The problem is the Printhead. The ink has dried up and therefore does not print. If you want to save the printer for  about  $15-20 there is solution that I bought that supposedly unclogges dried up printheads, I have NOT tried it yet, but being in the field it's just a matter of time. E-mail me back in case you have not thrown out the printer yet.
Oct 11, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
104 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
