Question about Frigidaire Washing Machines
New timer on my washer still won't cycle properly.
Hello:
I got this frigidaire washing machine from a friend. He said the washer had been hit by lightning through the power lines knocking the timer out. i replaced the timer but the washer still won't cycle through as it should. Is there any other part that would affect the cycling of the timer. If I manually turn the timer through the steps the washer will fill/oscillate, turn slightly again and it drains, turn another click or so it spins, then turn a few more clicks(according to the dial on front of the machine) it will fill/oscillate, and a few more clicks manually it will drain then force click it to spin and force it to stop. The machine on spin cycle will not spin all the water out of the clothes. Any information will be appreciated before I discard the machine in lieu of buying another.
Thanks jeff email jbkoinm@hotmail.com
    Problem Solver:
  • 7 Answers
SOUNDS LIKE THE MOTOR THAT ADVANCES THE TIMER IS NOT WORKING OR NOT GETTING VOTAGE TO IT. CHECK VOTAGE TO TIMER MOTOR
Posted on Jun 01, 2008
  • CHESTER EDGERTON
    CHESTER EDGERTON Dec 28, 2008
    sounds like you have a bad motor contoller. Computer located in the bottom of the unit
Frigidaire washer will not wash or spin
Hello friend, thank you for your post!
I understand that your Frigidaire washer will not wash or spin. Typically if your washer is not spinning it could be a potential issue with your drain hose. I would check to assure that there are no kinks in your drain line or that the drain hose is not too long. Those could be some possibilities.
If the drain line is clear you could be experiencing an issue with your timer or drain pump. I would recommend seeking assistance from a professional to come out and properly diagnosis your washer. I hope this helps. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
Why washing machine squeaks when in wash cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a squeaking noise during the wash rinse cycle on your Frigidaire washer. You could be hearing the noise from your motor during that operation, this is normal. Additionally, if you feel that this is noise an issue I would contact a professional to come out and diagnose your appliance properly. -Matt
Aug 23, 2014 | Frigidaire Washing Machines
Washer won't agitate but will spin
Hello friend, thanks for your post!
I understand that your Frigidaire top load washer, GLWS1740AS4, will spin but not agitate. It sounds like it could be an issue with the timer not allowing the cycle to advance or it could be an issue with the transmission in your washer. I would advise seeking additional assistance from a technician who could come out and diagnose the appliance properly, since it could one of two issues. Hopefully this is helpful. -Matt
Jul 24, 2014 | Frigidaire Washing Machines
Won't spin
Hello fopdycke - Typically when a washer does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage pump or hose may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, timer, faulty pump or control board not communicating correctly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 11, 2013 | Frigidaire ATF6000ES Front Load Washer
My washer won't spin
Hello Michael Johnson - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
Jan 04, 2013 | Frigidaire FAFS4272LW Washer
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front loader washer won't go into spin cycle after the clothes are washed
Sounds like you need a technician to diagnose the timer of the unit. Also the sensor that communicates to the timer.
Aug 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Front load washder does not go through with cylce
hello nplooj
welcome,
You said, front load washer would not continue through the cycle. For example, when I turn on the wash cycle, it will stay at that position and does not go to the next cycle. Every time I want the machine to move from one cycle to the next I have to do it manually such as from wash cycle to rinse cycle. The dial won't not turn unless I turn it manually. Please give me a suggestion of what part of the machine is not working properly. Per my understand and my friend told me, it is probably the time is not working. If that is the problem, can I replace the timer myself and how much it cost for the replacement part.
You do have an ATF6000 front load washer?This is made by Frigidaire or Electrolux
Did you get any error code?
Like an "F1" ?
Yes it can be replaced It is part of the,
Control Board,pc ,with housing $ 139.22
Here is the site with the parts.
http://www.pcappliancerepair.com/model-display.php
Let me know how you do.
Huuum,
Please remember to leave a rating!
Oct 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
138 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
