Question about Nokia 5310 Cellular Phone
Due a virus infection via downloaded theme, my nokia 5130 phone software includig music player does n't work...when i try to open a music file it shows not enough memory......phone brower,phones default themes all deleted..........how can i fix this
    Sergeant:
  • 172 Answers
Restore your phone to factory settings.
Posted on Oct 13, 2010
My nokia 5130 before on only nokia icon display and not work any function
Hello Flashing is the only way to fix this problem,so if you wish to do Click here1 for instructions and for flash file select it from this All nokia bb5 flash file.Or you can contact nearest mobile repairing shop.This problem arise because the OS of your phone is corrupted/damage....this could be happen when using of memory card with a virus infected files/when you transfer data via bluetooth/virus infected PC.Good luck.Thanks for visiting fixya
Aug 29, 2012 | Nokia 5130 XpressMusic Red Unlocked Import...
My mobile music player unable to open. When i try to open this, they says not enough memory. N also browser unable to open. Also unable to download app due to certificate proplem in mobile and sim.
Just follow the instructions and do it there will be no problem at all.First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck
Sep 06, 2011 | Nokia 5130 Cellular Phone
My set suddenly hanged switch on it light hanged. nothing works switches.
I think that some virus might infected to your phone so you need to flash/update.Just follow the procedure below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
Aug 29, 2011 | Nokia 5130 Cellular Phone
I got a problem with switching my mobile theme its model is nokia 5130 xpress music when i use another theme there is a massage says unable to open theme corrupted
Hi your problem to your cellphone nokia 5130,if the themes cannot be open to your cellphone or corrupted.if the themes you get from bluetooth or from download,you can't avoid to get a virus because the bluetooth or download, you need to scan from antivirus before you apply to your cellphone.if the themes cannot open or corrupted its mean not supported to your cellphone or try the others themes that same of the capacity of the phone.
Jul 22, 2011 | Health & Beauty
My nokia 7210 shows OPERATION FAILED wen i start MUSIC PLAYER AND RADIO. I am facing dis problem from last 15 days. All the other features are working properly except MUSIC PLAYER and RADIO.
Yes all the other application should work.First follow the steps i have given and if possible SCAN Virus of your mmc .Because the Music player might infected by virus
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link7210c flash file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 13, 2011 | Nokia 7210
I can't open my music player in nokia 5130. phone system say me `not enoug memory but my phone memory is empty'.
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone still does not open the music player then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 06, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
My nokia 5130 shows nt enough memory for playing music in music player....bt in real the phone memory is empty..wt i can do now...plzzz give me solution as soon as possible....thankuuuuu
I have seen this kind of problems with the Nokia 5130, I flashed the Nokia 5130 by taking it to Mobile Service Center. Now it's working fine, everything is working as expected! So please flash it by taking to any Mobile Service Center.
Mar 26, 2011 | Nokia 5130 Cellular Phone
Everytime i try to open the downloaded c3 themes it always says "file not supported"
meaning you downloaded the wrong themes for your phone. Go to zedge.net to download a specific themes for your NOKIAC3. thanks
Jan 09, 2011 | Nokia C3 Cell Phone
Please help me...my nokia 5130 has a problem...when i am openning music player or radio the not enough memory box is always appearing...and my calculator lost...and also the opera mini,i cant open....and...
download the flash software for your phone try googling for it...
or you want it done from somebody...visit nokia care and tell them to flash it for u..
ur problem will get solved
Sep 05, 2010 | Nokia 5130 Cellular Phone
Nokia 5310 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
