Instruction maunaul for pro technnik pt-65 - Audio Players & Recorders
  • 44 Answers
Try this:
http://www.protechniklab.com/support/manuals/pt-65_Eng.pdf
Posted on Oct 13, 2010
  • doubledeez Mar 24, 2011
    This Site doesn't work
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Jan 20, 2013 | Brother BRTPT65 PT-65 Label Maker Printer
Cant find label refills
Hi there, Go to Find.com and key in Brother BRTPT65 P-touch Model PT-65 home and hobby label refills. It will take you to a varitey of different labels showing the prices. Make sure you click on the labels and make sure they are the ones compatable with your machine. Hope this helps!
Jan 15, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Need Instruction Pamphlet
I need instruction on how to getrid of unwanted background
Aug 13, 2010 | Brother BRTPT65 PT-65 Label Maker Printer
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Brother PT 65 Label Maker
i've never been able to change the font. just sizes, and make it BOLD, Italic, underlined ect.
only one style font however
Dec 31, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
146 people viewed this question
 Grubhead
Grubhead
