Question about Whirlpool Refrigerators
Whirlpool model GX5SHDXVD01: Need to put filter on icemaker; the\r\nphoto in the store showed a vague location at the bottom front of the unit. Store sold me #4396841 filter. Any info on this model?? Thanks, Jim jimdebmoss@yahoo.com
mikedurland
  • 481 Answers
SOURCE: Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Posted on Jun 28, 2008
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
SOURCE: Specifications & Price on LG -bottom freeze frigidaire size 10-18cub.
I found the place whit European product in Montreal. . I was also able to found the specification through the other web side.
Dusana
Posted on Oct 07, 2008
jyackle5
  • 8197 Answers
SOURCE: Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ET1FHTXMQ04&siteCd=WHRCOM
Good Luck and please rate FixYa!
Posted on Apr 11, 2009
buffalonyman
  • 1865 Answers
SOURCE: Kenmore Elite Trio 22.4 Cu Fridge - Flecks of "Tin Foil" in Ice
Perhaps the solution to to change out the ice maker unit
Posted on May 03, 2009
How do you actually remove the screw plug to access filter to clean (instructions are vague & worried I'll break it)? Water is still in drum after draining.
How to Check to See if the Drain Pump Filter on a Whirlpool ...
homeguides.sfgate.com > Landlords & Tenants > Tenant Credit Checks
When your Whirlpool washing machine won't drain, there's a possibility that ... drain pump filter are easy to disassemble so that you can access and check it. ... Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. ... Hold a bucket in front of the pump while you remove the knob to catch the water.
How To Fix Whirlpool Duet Front Load Washer Not Draining ...
www.appliancerepairlesson.com/.../whirlpool-duet-front-load-washer-not...
Dec 2, 2013 - If the washing machine does not drain, then it will not spin. ... To gainaccess to the drain pump and filter you will need either a 1/4 ... Removing the screws will allow the front panel to drop down giving access to ... I have seen where once you clean the filter and test the machine it ... Really ridiculous design.
How to clean the pump filter and coin trap on a Bosch washing
? 5:30
https://www.youtube.com/watch?v=e9YtFBi_wnc
Mar 2, 2013 - Uploaded by whichwasher2007
Feb 03, 2016 | Whirlpool Washing Machines
How do I access the drain pump on a Whirlpool Duet washing machine model WFW94HEXW2?
Hi Marc,
Unfortunately, access to the pump & filter is harder on the HEXW2 model than the Duets with the removable lower panel.
First you have to remove the lid panel (screws in top rear), then pull slightly rearward and up/out.
Next you'll have to remove the control panel, then remove the front drum boot from the front panel lip. A large diameter thin wire spring holds it in place, located just under the rubber lip edge. Begin the spring removal from a wire tab located toward the lower portion of the lip.
Then remove the door latch screws (IIRC), and the screws at the bottom edge and top of the front panel. The entire front panel must be removed to access the drain filter.
Nov 03, 2014 | Whirlpool Washing Machines
Ice making not making ice
Cycle the icemaker with the reset button. It is located on the bottom-front of the icemaker. Press and hold for 8 seconds to complete a cycle. You should hear an audible reset tone from the refer when complete. If it still doesn't work later in the day, it may need replaced. These units are well known for deplorable ice making capabilities. Samsung considers 60-72 cubes per day to be acceptable. I consider it an insult. For the icemaker reasons alone, I am looking into another (domestic) brand.
May 30, 2014 | Samsung RF265AA Bottom Freezer French Door...
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
Filter needs changing
You don't need a plumber. The filter is located inside the fresh food section, in top-right corner. There is an elongated cover with a tab in front. Press the tab towards the back of the fridge slightly and pull the cover front down. There is your filter. No need to turn the water off either. Just twist the filter counterclockwise and it will pop off.
The part number of the filter is UKF8001, can be purchased in any appliance parts store, for example here. "New10"coupon takes 10% off.
Nov 09, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Is there a filter on the water for my Refridgerater Model #FRS20WNF. If so where can I buy a new filter and how do I replace the existing one? The water is starting to taste funny.
HI. This unit is not equipped with a water filter. If there was a filter, it would be located on the front/lower grill area(bottom part of your unit). It would be accessible there.Unfortunately, this unit dose not have a filtration system.
Oct 22, 2009 | Frigidaire Refrigerators
Try to find out if this unit needs a filter for the icemaker
Your refrigerator will not accept nor was designed to use a whirlpool water filter. No a filter is not required. Yes an in line filter can be installed prior to the connection at the inlet valve if you desire.
Apr 02, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
I have a Whirlpool side-by-side refrigerator and I can't get the icemaker front panel off to install a new icemaker kit in order to fix the frosting around the icemaker chute. How does the icemaker front...
according to the model number that you listed in the heading it just shows a cover door that slides out and down and is attached to the top freezer shelf. is this correct? If so pull one side of the slide and it will release the cover.  Now if your talking about removing the dispenser cover on the fron of the freezer door there are 2 slots on the bottom of the cover that you insert a flat tip screw driver and carefully pry the cover off. hope that helps Peyton
Jan 27, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
