Hannspree tv Product No.JT01-32EI-000G Type T23B When i turn tv on the screen keeps flashing which is in blue. When i try to changes channels you can hear a clicking from the rear of set,the sound works ok. can you help me Peter.
  • 4 Answers
SOURCE: 50PFP5332D Plasma tv. My tv sounds like its trying...
I have the same problem with my TV. I haven't verified this yet, but someone I know who's a electronics genius told me that its the buttons on the TV (power, channel, volume, etc.) He said at the factory many of the "button boards" were tightened too much and cracked. When you turn the TV on, the clicking noise is a loose connection. He said it's easy to replace yourself, and about 30 bucks on ebay. No promises though.
Posted on Sep 20, 2010
full str pka
  • 14 Answers
SOURCE: no signal and blue screen
hello
i think you might have a blue screen of death on your tv
--full str pka
Posted on Dec 31, 2008
  • 64 Answers
SOURCE: where can you purchase a new power supply for a
try a search engine by the card code. You cannot find it by the tv model because the same card can be used in many brands and models. Open the tv inside and read the power board model or serial etc. write down everything and start google. Perform a perseverent search. :)
Posted on Jan 29, 2011
diodeic
  • 1622 Answers
SOURCE: my hannspree t23b has sound
The Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will help out in solving the problem....
Posted on Jun 16, 2011
  • 121 Answers
SOURCE: hannspree tv t23b no sound or picture
Check the wires very good on the back if still not working look on you tube for a video on it
Posted on Sep 26, 2011
Hi there, I have a Hannspree XV HDTV, product # JT02-37U1-000G, it stuck in the volume adjustment screen, my remote(not original doesn't make it work,also the button on the tv too).please help
Unplug the television from mains first take the batteries out the remote then plug the tele back and switch on from the television see what happens if it goes back to normal the you have the volume bottons jammed on your remote control
Nov 16, 2017 | Hannspree Televison & Video
Hannspree JT0237E2-000G Sound but no picture have checked power supply with meter which seems to be ok so which card do i now change
main board and the other board, oh lord tv\'s are such a mess--- replace the video board which is the one with ribbon cable going to it from the lcd, the boards can be expensive so if you have time and a multimeter the you can track down the service manual and then use your meter to check certain points on the other boards for correct voltages- with each component voltage will vary, if you know the values of the components then you can calculate the voltage that should be at that point- hard work but effective and inexpensive, keep in mind something cause those parts to fail in the first place, and that something is what you wanna track down during your repair, just because a component looks ok does not mean it is, which is why that volt-o-meter is you best friend for this type work. I have way too much advice to offer so im going to shut up now--- good luck questions just ask
Mar 30, 2013 | Hannspree Televison & Video
37"JT02-37E1-000G LCD Hanspree TV Unable
I have same model tv but power supply board is faulty. I am in India. Any suggestions for repair or replace the power supply board.
Moses
Sep 01, 2011 | Hannspree Televison & Video
Where can you purchase a new power supply for a hannspree 32" JT01-32-U1-000G?
Jan 29, 2011 | Hannspree XV32 32 in. LCD Television
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Electro Med Services...
