Question about Whirlpool GU2400XTP Built-in Dishwasher
Sprayer arm won't turn - Whirlpool GU2400XTP Built-in Dishwasher
  • 4,323 Answers
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
Under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... If it does please do not forget to accept the solution or post back with the make and model number of your dishwasher for assistance.
Posted on Oct 13, 2010
The top sprayer holes on sprayer arm are blocked, how does sprayer arm come apart to clear blockage?
The sprayer arm does not come apart. You have to remove the sprayer arm and use an object that fits in the holes to clear the blockage.
May 28, 2012 | Kenmore Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Finish Dishwashing tablet does not dissolve and our dishes do not come out clean. We have used a product to clean dishwasher, but to no avail.
Many dishwashing detergents need a water temperature of 140 degrees to dissolve. If your water is at the correct temperature, the only other suggestion I have is to make sure the detergent dispense is not blocked by large objects such as baking sheets, frying pans etc. If the dispenser cannot open fully, the detergent won't dissolve.
Also, you might want to check the sprayer arms. If they are clogged, they won't turn effectively. Sometimes debris will be pumped into the arms but the openings are too small to release the debris. You can remove the arms by removing the screw that hold them in place and then flush the arms with your sink sprayer. Then you can check the openings to see if there is any "crud" left in them. By crud, I mean small pieces of paper, bone fragments,
I hope one of these suggestions helps you. If it does, please rate my effectiveness. Thanks
Jun 02, 2011 | Maytag Dishwashers
Dishwasher won,t clean dishes ontop rack
Make sure the top rack is pushed back all the way to connect with upper sprayer arm water port. Also make sure nothing is preventing either sprayer arm from rotating and there is nothing blocking the sprayer arm holes, like seeds or pieces of plastic debris. Also make sure your water heater temp is hot enough.
May 18, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
My dishwasher does not clean my dishes good
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Usually in the center of the spray arm is a wing nut. Simply unscrew this to remove the arm(s). Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 05, 2010 | Kenmore Dishwashers
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | GE Dishwashers
Spray arms blocked how do I detach clear/clean them?
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. In the center of the sprayer arm there is usually a wing nut that unscrews easily and releases the sprayer arm. Once you have removed the arms, rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | Bosch Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
80 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
