Question about Compaq TFT5000 15" LCD Monitor
Only one time show ok display on power on than convert black dispaly
    New Friend:
  • 42 Answers
This is an old monitor, I remember working on these many years ago.
Anyways, the backlight is bad. The CCFL bulb needs to be replaced.
It is cheaper to scour ebay or something to get another one if this is in a server tray than to get it fixed.
If not, just buy a new monitor. You'll see a world of difference in picture quality.
Posted on Oct 13, 2010
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
I have HP Officejet 5610 All in One printer, When i am switch on the power button the dispaly showing intializing and after a few seconds it shows date & time and then suddenly one noise coming from...
Its time to reset the printer; follow the below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Nov 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi, when i power on it shows in brown color, (blink in brown) nothing dispalys, i changed ps, memory, processor. but didn work out
The only thing that's left is your motherboard. The usual culprit in a black out mode is the power supply and the motherboard. Try using a certified good motherboard. Try also to check on the display card. Also, check for compatibility of the power supply, the motherboard, the processor, display card and the memory
Sep 13, 2010 | Dell OptiPlex GX520 PC Desktop
Was pink at bottom now a black screen. powers on for a second or two then black screen. green power light is on.
Check whether the connector has been properly connected to the computer. Also try to boot the system with safe mode option and you are geeting display, then install the appropriate display drivers will solve your problem.
Also check the DPI setting configured in dispaly properties.
Dec 15, 2009 | Envision H22W 22" Monitor
UNABLE TO ADJUST THE SCREEN ALWAYS SHOWING MENU LOCKED
When you press power button press continues F8 key then you see safe mode and other menu enter in "ENABLE VGA MODE'
then go to dispaly property and settings then change screen resolution to 1024.768
then apply and ok.
Aug 18, 2009 | Lenovo ThinkVision L151p (Black) 15 inch...
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
No display on nokia 5200
Consider replacing the screen. This a good phone. It is not expensive to repair too.
Good luck.
Rate fixya
May 27, 2009 | Nokia 5200 Cellular Phone
No display on Philips Freevents X59
It the back light or its converter stop working. Do you have any dark dispaly which can been if yoy see carefully in light?
Apr 12, 2009 | Computers & Internet
NOKIA 2760 DISPLAY LIGHT PROBLEM
nokia 2760 dispaly light problam
Jan 17, 2009 | Nokia 2760 Cellular Phone
Compaq TFT5000 15" LCD Monitor Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
