Question about DeVilbiss Air Tools & Compressors
Hello, the gun has been stripped down and cleaned but when I put paint in and spray, the spray fan goes from being good to spluttering. Another thing I have noticed is that air bubbles rise from the centre of the cup that holds the paint. Many Thanks for your help.
  • 700 Answers
As you did not provided exact model - i assume that this one is gravity feed.
this is generic solution for your problem, assuming that there is no crack in the nozzle.
you mentioned that you cleaned it - did you removed little filter on the bottom of the cup and changed for new? they cost just few cents each and get clogged easily. replacing them is more cost effective than cleaning them.
now, i would suggest removing paint from the cup, wash with appropriate solvent and spray little solvent through. fill now cup with about 1/3 to 1/4 paint stripper and spray that to sink or other receptacle - DO NOT FORGET GOGGLES OR EVEN BETTER - FACE MASK! YOU HAVE ONLY TWO EYES AND NO SPARES!
just in case - prepare 2 or 3 pints (1 to 1.5 liter) of water with few spoon of vinegar in it - it will neutralise paint stripper if splatter on your body or paint which you want to preserve...
now, prepare sheet of butcher paper, pull gun apart removing the needle, check tip for dirt, damage, bends - clean and repair if necessary or exchange needle for new one. needles are usually made of stainless and have dull sheen on them
check nozzle - remove any residual paint, check for cracks and any physical damage, i do that usually at 20x magnification for airbrushes and 5x for other air guns. there are temporary repairs to cracks but usually replacement is only solution.
grease lightly all springs and working surfaces with ptfe dry spray, if you do not have that grease, use petroleum jelly (vaseline).
put gun together in reverse order in which you disassembled it (you put parts in the order on the butcher paper? :-)).
now, i assume you know what each button do on your gun, but just in case, bottom screw (closest to the air input) regulates airflow to the gun, middle screw regulates volume of the paint, and top screw or in some models side screw regulate pattern. close all screws.
fill cup with water (you did insert new filter?), there should be no leaks of air or liquid anywhere, needle should be not retracting.
open air volume screw on the bottom to the desired pressure, in case of water based paints - it is about 40 to 60, depending on the thickness of the paint.
hold needle retracted and lose the liquid flow till you achieve regular flow from the nozzle, on vertical surface for about 15" (400mm), diameter of the water circle should be about 8" to 10" (200mm to 250mm), it can be bit more if you are using very, very thin paints, inks for example or solutions,
now, go to third valve and open it till you acquire desired oval.
that is all what it is for setting up any airgun, including airbrush (only diameters and distances are smaller).
now, water based paints have nasty habits of precipitate from the solution, only way to avoid that is to shake it well before every refill of the cup and filter as it go to the cup. 100 filters will set you about $15.00 in paint store (in hardware store it will be about 10 of them for same money....).
now, we check everything, is clean and spanky - and still clog the nozzle... problem is paint is too thick and you need to replace nozzle for large one, most "solid" water paints require at least 1.8mm nozzle and up to 25% dilution, i am usually using 2mm or even 2.5mm or bigger nozzle for water paints.
if you try to spray water based latex paint - you need a minimum 2.5mm nozzle, i am using even 4mm for that particular paint.
if you find my answer useful - do not hesitate to put some points my way... if you have any questions, including some clarification - feel free to ask.
Posted on Oct 24, 2013
Again you have to change the fluid nozzle it help me with my spray gun
Posted on Oct 22, 2010
How can I fix a electrical spray gun that does not spray but makes noise like its going to spray.
R D, I think the spray nozzle is blocked with previous paint job. I would try soaking it in paint solvent for a few hours to see if it helps. Use the cleaning brush to clean as much as you can all the channels where you see paint. good luck.
May 20, 2014 | Wagner Spray Tech Model 242 Electric...
Paint gun not shooting correctly
Seeing how you have really stated what the problem is (spitting, clogged, won't shut off, fan pattern wont adjust Etc) and there could be several different things wrong- lets go over some basic spraying A B C'S- always strain the paint through a strainer bag or cone this will remove any debri that might clog the tip, *THINNING when you spray or atomize paint it should always be thinned it will actually cover much better if you thin it with the appropriate solvent water for latex thinner for oil base you want to stay in the 15% range alittle bit more on hot days. The shape of the spray that comes out of the tip is called "fan pattern" or "tip fan" "fan size" you can adjust the fan pattern from 9:00 - 3::00 or sideways to straight up and down or to a small circle this is done by moving the "tip housing retainer" keep a piece of cardboard to practice and see. IMPORTANT:When you have finished spraying you need to clean the entire gun by running the right solvent through the gun untill nothing but clean solvent is coming out dissemble the gun remove and clean needle and needle housing this is not very complicated and is paramount to maintaining any spray equipment for sure the gun....
Perry Tradesman
Dec 29, 2013 | GRACO INC 3900 Handheld Paint Sprayer...
Iwata eclipse G6 airbrush gun - no paint flow, bubbles forming in gravity feed bottle.
it is rather large (usually 0.6mm nozzle) airbrushing gun,
symptom indicate that needle is closing the nozzle and not retracting, gun need cleaning! or adjustment - seem like both...
remove paint from the feeder, remove feeder bottle from the gun body, clean it well with paint stripper and then solvent/water allow it to dry
remove front casing from the gun and check for any physical debris around the needle or in the chamber, carefully clean without damaging the needle. needle is stainless should be nearly mirror finish.wash with solvent and use toothbrush - DO NOT USE METAL BRUSH!
put it back together and check if it works correctly, if you have any flow from the front - fill about 1/3 of the tank with paint stripper and then spray it to the sink or whatever other safe place. do not forget to wear safety mask, goggles and gloves! paint stripper will eat through your skin! if you splash yourself, have few spoon of vinegar mixed with 2pints (1 liter) of water and this solution will deactivate paint stripper! SAFETY FIRST!
if gun still do not work - you need to strip needle assembly and clean it correctly, put your gun on the table on butcher paper, remove screw holding needle on the back (watch for the spring!) put whole assembly on the paper in the order in which you removed it,
clean needle and needle seat, lightly grease it with vaseline and in reverse order put it back together.
regulations:
very bottom screw - this close to the airhose, it regulates volume of the air to the gun, you very rarely need to adjust that one, you increase volume with haevy paint and decrease it with light paints
needle screw - it regulates volume of the paint itself, closing it clockwise will decrease amount of paint, anticlockwise will increase volume of paint
top screw - it regulates the spray pattern, totally closed - round pattern as there will be no flow to side vents, more open, more flat the spray pattern,
i would suggest fill the bottle with water and put some butchers paper on the wall and experiment what is what and what pattern is most suitable for your use.
hope this little info will help you solve your problem, it is good you give the model, it will be better if you provide as well what medium you use, was it acrylic, oil, water based? all of them behave little bit differently in airgun...
please do not hesitate to leave your opinion and points... thanx!
Oct 04, 2013 | Air Tools & Compressors
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
Over spray or fish eyes
Over spray is just that getting paint on a surface you are not painting (protect adjacent surfaces) "fish eyes" are almost always some type of oil wax or something that was not cleaned off and the paint film moves away from it- always clean all surfaces first before any painting.
Perry
May 27, 2012 | Air Tools & Compressors
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
The trigger on the spraygun for my Magnum SR7 sprayer is slack - doesn't operate at all and won't release any fluid from the nozzle.
This is a contractors gun its a vary good gun worth about 200 hunderd dollars . The problem is eigther the spring that returns the trigger _neddle valve to seat pisition is eighter stuck or broken. But if you are haveing this kind of problem it means the gun was not cleaned correctly . Im a perfinial spray painter and if the gun isn;t clean then the mechine wasn;t cleaned as well it goes hand in hand . So what kind of mechine are trying to opperate its an airless acording to the picture and that makes sence . You may be able to clean the gun or get a kit to rebuild it its about a hunderd dollars but the mechine most likely needs to be cleaner at best if no completely rebuild and repacked . If the seals in the pump can put out pressure and the trigger on the gun is slack then you shouldn't be able to shut the paint off because the trigger would be open at this point
Jul 10, 2011 | GRACO INC 255109 SGPRO Paint Spray Gun
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Can't get the paint to spray out of gun
strip the gun down and clean all the passages where the fluid goes.
make sure you are getting fluid through the line that connects to the gun.
Nov 13, 2009 | Wagner Power Products 0154842 Medium Spray...
Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Feb 09, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Air Tools & Compressors Logo
608 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
