Question about LG Dishwashers
Hi I have a LG dishwasher, model LD-2052WH/LD-2052SH/LD-2052MH. The machine is about 30 months old, and used very seldom. In the last two weeks we noticed a very loud "grinding" sound emmiting from the machine. This sound usually happens when you switch the machine on as the water if filling or the wash blades are rotating. What is the cause of this, and how can I get it fixed? Regards Paul Naidoo Ph: 0027 83 651 7558
catriver
  • 878 Answers
SOURCE: Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Posted on Dec 30, 2006
SOURCE: LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Posted on Oct 20, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
  • 351 Answers
SOURCE: LG Dishwasher Model LD-14AW3
you have a blockage in the drain pump.they are difficult to get to.
Posted on Mar 28, 2008
LG Dishwasher LD-1420T1 Tripping the main Power Board
Looks like the pump motor is drawing lot of current and tripping the circuit breaker. Need to check if there is any water inside it. Or simply the capacitor is leaky and causes motor to draw current.
See this part.
http://shop.onlineappliancespares.com.au/part/4681ea2002f-134640/43518
Apr 07, 2014 | LG Dishwashers
LG dishwasher LDF6920ST - Power button lights up but the cycle buttons stopped working so the unit wont turn on to wash. The Power Scrub cycle button seems to be pressed down farther than the other...
Hi Mark.
Modern LG appliances retain settings even after you disconnect the power cord. The machine is reset opening the door and then pressing and holding the Normal and Delicate buttons at the same time for 3 seconds.
You can also try running the test mode shown at page 12 of the service manual.
If the machine is non responding and there is no code on display, then the problem is likely control module or control pad. Since the control pad looks defective, that is probably the part to replace.
Disassembling is shown in exploded view and service manual available using the links below:
Parts and diagrams are available here.
A copy of the service manual covering several LD models has been uploaded here.
Regards.
Ginko
Dec 01, 2011 | LG LDF6920 24 in. Built-in Dishwasher
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Our 3 month old machine started making a high pitched squeel the other day during the wash cycle. Now it has started on the rinse cycle on the Quick setting. Model LD149.
I share your frustration with the same machine. Mine is approx 3-4 months old and within the first month i had a leak at the base of the machine which was fixed under warranty. The following month the machine started leaving water in the base of the unit after the wash cycle was complete. LG claim it is an electronic fault in the circuit board. I have refused repair and am now claiming a replacement with them. I don't feel it is acceptable for a machine that's only 3months old to give problems such as these.
Mar 28, 2011 | LG LD-1420T1 Dishwasher
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
LG Dishwasher LD-1403W - loud whirring noise during wash
We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
Jan 01, 2010 | LG Dishwashers
Hi, I need a manual for LG LD2131 SH
Hi
Thanks for using FixYa. You can download the user manual for your dishwasher from this link--
LG LD 2131 SH Dishwasher User Manual
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | LG Dishwashers
LG Dishwasher Model LD-1403W gets stuck and stops on rinse cycle leaving water in bottom of machine. I have stripped it down and emptied it, made sure filters etc are clean but to no avail
LG Dishwasher LD 1403W. We have cleaned it and when it gets to the heating cycle after running right through to nearly the end, it trips all the electricity and stops everything. Its only 3 years old and hubby thinks its the heating element but between $200=$300 to fix.
Apr 10, 2008 | Dishwashers
E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG Diswasher model LD-14AT2
NEED TO SORT OUT LEAK FIRST AS THIS HAS ACTIVATED YOUR SUMP LIMIT SWITCH. THE CYCLE WILL NEVER PROCEED OTHERWISE.
Jul 29, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
76 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
