Question about Toshiba TDP-T9 DLP Projector
My tdp -t9 toshiba projector is showing two vertical white lines with or without any laptop connection. Does this mean the lamp needs to be replaced?
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
Marrie
  • 563 Answers
SOURCE: Trouble with output to the projector
Hi there
Check the following on your laptop.
Right click on your desktop , go to properties and settings - check if your resolution of the PC is the same as that of your Projector. i.e. 800x600 or 1024x768
Also check that your secondary monitor is attached / activated.
If the signal stil won't pick up - hold down the Fn ( function button) left of your spacebar and press in your F-row of buttons the one with 2 screens on it. ( differs from brand and model )
Hope this helps you and good luck with your class tomorrow !
Posted on Mar 31, 2008
  • 7 Answers
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
SOURCE: Toshiba TDP-T90 projector, lamp
I have the same problem. The lamp cover has a tab that sticks up about 1/2 inch. When you close the lamp cover the tab presses on a wire that allows power to the lamp. You can hear a 'click' as you close the cover slowly. My tab kept bending over preventing it from depressing the wire. I've straightened it several times to where now it broke off to where it wouldn't work at all.
I fixed the problem by clipping off the tab, inserting it in the bulb case to press the wire and taped the tab in place.
Posted on Dec 02, 2008
  • 4 Answers
SOURCE: I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Posted on Jun 24, 2009
I have connected my toshiba TDP-T9 to my laptop but I'm getting a "No Signal" error on screen. Could my VGA cord cause this?
Depending on your laptop, the internal splitter may be turned of. Usually the keystroke to turn it on is Fn F8. However it may be different on your laptop. Look at the function buttons, and the one with a screen looking thing on it is the one you press with your "Fn" key.
Jan 27, 2011 | Toshiba TDP-T9 DLP Projector
It suddenly stoped playing clearly. i can see some extremelly pale picture.my lamp is around 2000 hrs the projector is a 2004 model toshiba TDP-D2.any ideas?thanks panos
You need a new lamp. You can purchase one at:
http://www.shopvsc.com/Toshiba-Replacement-Projector-Lamps-s/143603.htm?searching=Y&sort=7&cat=143603&show=50&page=1&f-TDP%20D2=143381
Oct 25, 2010 | Toshiba TDP-D2 Projector Lamp
My projector is showing multiple white dots, looks like lots of small stars all over the screen when projected to screens. is this mean I need to replace the lamp? TDP-XP1 model.
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
Oct 19, 2010 | Toshiba TDP-SP1 DLP Projector
Toshiba TDP-T9. the light won't change from yellow to green. we tried restarting the computer and the projector, but nothing seems to work.
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
How do I get rid of this one vertical white line on my toshiba TDP-S8
take the cover off, disconnect the the connection on the rear of the lens assy from the main board, clean with an approved electronics cleaner and then reconnect. Sometimes this fixes the problem. If it doesn't, then the DMD on the rear of the lens assy is bad or the main board is bad. Hard to tell without a test fixture.
May 20, 2010 | Toshiba TDP-MT800 Multimedia Projector
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T9 DLP Projector Logo
138 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
