Question about Ovens
Main oven not heating up but fan is working on kenwood ck405 oven
  • 744 Answers
Kenwood Oven not heating? How to replace a Kenwood fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jan 30, 2014
  • Ovens Master
  • 3,463 Answers
Normally, if the fan is working o/k, then it is usually the oven element that has failed,n ormally located at rear of oven compartment behind a removeable cover.
Posted on Oct 13, 2010
2 Suggested Answers
  • 119 Answers
SOURCE: kenwood ck405 - main fan assisted oven not heating up
If you are crafty undo the screws on the element and pull put slowly you will see the wires todisconnect
Posted on Feb 17, 2010
My oven door is not opening all the way. It seems to be something with the hinges.
You searched for Kenwood element How to Repair Home Appliances
Jan 30, 2014 | Viking Ovens
My kenwood CKB200 oven tripped my mains circuit. When I put the power back on the Oven did not heat up as well as before. I am assuming that one of the elements has gone. There is less heat at the bottom...
ISOLATE THE MAINS POWER BEFORE OPENING ANY PANEL ON YOUR APPLIANCE
There are sometimes up to three heating elements in simular types of ovens.
A Visual inspection is required to accertain which is the element not working, remove rear panel, there is odd types that have the element to the side of the fan assisted oven, have a good look when panels removed. The blow element usually has a blow out hole with Black Gray at the point it will feel rough not smooth like the rest of the element case, the second way is a bulge on the surface skin, it should be easy to identify. Part could be obtained through www.whitegoods.co.uk you will need the model and serial numbers. Some models you have to remove the fan or fans if twin, some models have top fan usually no element in the top except grill.
Hope this has been helpful please send me info if more tech is required.
John
May 20, 2011 | Ovens
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
May 07, 2010 | Zanussi ZBF360X Electric Single Oven
Kenwood ck405 - main fan assisted oven not heating up - grill working, fan working but think it might be the element - how easy is it to replace element?
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Kenwood element How to Repair Home Appliances
Feb 17, 2010 | Ovens
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
How do you remove the element of a kenwood ck405 oven element to allow cleaning
You need to first pull the oven out from the wall. Then unplug the oven, then remove the rear panel on the oven and there you should have access to where the element connects and you can disconnect it from the oven.
Let me know how this works out for you.
Benjamin
Jan 10, 2010 | Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
The main oven dose not heat up the fan works and
The oven element will have failed due to the fan intermittently working.
You will\ need to replace both the element, and the fan motor, to ensure a satisfactory repair.
Please rate my solution.
Thanks.
Nov 15, 2009 | Ovens
Ovens Logo
305 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
