Question about Zanussi Washing Machines
I need to clear the filter on my zanussi zwf16070w washing machine but dont know how to and cannot find the manuel for it??
  • stars061 Oct 14, 2010
    Thank you, I think it works now
  • Zanussi Master
  • 3,463 Answers
If it is a british made washer, then the filter is usually located at the bottom front right of washer behind a drop down flap or cover, unscrew filter anti-clockwise to remove and clean.
Posted on Oct 13, 2010
Testimonial: "Thank you for quick response."
  • stars061 Oct 13, 2010
    will a lot of water come out from the filter when I unscrew it?
  • Barry Coates
    Barry Coates Oct 13, 2010
    It depends how much water has drained from washer, be prepared for a flood. have some cloths handy, oir if you can remoe drain drain hose from outlet pipe and syphon water out first.
The washing machine has stopped midcycle and the start button is flashing red do you have any ideas of what may be causing this?
try to cancel it out and start again, if it won't cancel machine is telling you that something like belt broken or door open, etc.
Sep 22, 2015 | Zanussi Washing Machine Door Seal...
Zanussi zwf16070w drain pump wiring
Hello!
You can connect them anyway, it works with AC, there is no + or - on the pump.
Feb 26, 2018 | Washing Machines
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
Mar 26, 2010 | Zanussi ZWF1650W Front Load Washer
Zanussi washing machine will not empty
There should be a filter located at the bottom right front of washer behind a drop down down cover.
Unscrew the filter anti-clockwise to remove and clean.
If filter clear, then possibly the pump is faulty.
Hope this helps you with your problem.
Dec 02, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Oct 06, 2009 | Zanussi ZWF1430W Front Load Washer
Hi - I have a Zanussi ZWF16070W.When set for 1600 spin, it intermittently finishs the cycle and clothes are far from dry/spun. I have checked obvious filter for clogs etc. When I reset to spin cycle only...
Check the motor controller, and also the lid switch for proper operation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Zanussi Washing Machines
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
372 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
