Question about HP Photosmart C6180 All-In-One InkJet Printer
I HAVE AN HP PHOTOSMART 6180 ALL-IN-ONE. I AM RECEIVING THE " INK SYSTEM FAILURE .... ERROR 0XC19A035 MESSAGE AND NONE OF THE ABOVE CURES SEEM TO HELP . DO I GET MY PRINTER REPAIRED OR GET A NEW ONE?
Roop1980
  • 228 Answers
SOURCE: Ink System Failure (Error 0xc05d1381)
To resolve the issue, use the following steps.
Step one: Remove the cartridges
Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
Open the product cover and remove the cartridges.
Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
Open the product cover and reinstall the cartridges.
Close the cover and print a calibration page, if prompted.
Print a self test report to make sure that the product can print.
Reconnect the USB cable between the product and the computer.
Try to print a document from an application on the computer.
If the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
Posted on Apr 11, 2009
SOURCE: oxc18a0201 ink system failure. Apparently
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
Posted on May 28, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
Model 6180 error Ink System Failure Oxc18a0206 - won't shut off either or print
mportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) to solve this error:Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.note.pngNOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon (c01424575.gif ).Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product.
  10. Try printing again.
Oct 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0306. Ink System Failure?
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0105. Ink System Failure?
May 04, 2011 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart D6160 - says ink is empty when it isn't
I have had this problem of receiving an error message saying that the yellow cartridge is empty on my Photosmart D6160 when it was not empty. Strangely the use of the 'Black Only' button produced a COLOUR image, including yellow!
I seem to have cured this problem by:
1) removing the printer in the control panel
2) switching off the printer and unplugging it from the computer
3) replugging the printer and switching it on.
4) watching the computer as it automatically reloaded the printer driver.
Note: The operating system I am using is WINDOWS 7. The printer was working fine with this OS before the above incident.
Also you can check the ink levels/colours by pressing continuously on the printer's power button, pressing the resume button (downward arrow) once and then releasing the power button. The printer then prints out a test/diagnostic page giving the ink status.
Nov 03, 2009 | HP Office Equipment & Supplies
6180 rebooting
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn the machine on, wait until the printer prompts that the ink cartridges are missing, then replace the ink. If this doesn't fix it you may need to re-prime the ink lines using the directions at this web page http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Oct 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
