Question about Sony Car Audio & Video
Sony car stereo
Has removable front panel. My husband has been taking it off every night because of thefts in the neighborhood. Got a call from my husband this A.M. that, when he went to put it back on the car, he could not get it to work. It seems dead. Any suggestions as to what the problem may be?
  • 109 Answers
Check the radio fuse on both the deck and in the car's fuse panel.
Posted on Jun 07, 2008
Sony car stereo
be careful withn that stereo u could trigger the anti theft system in ur car then ull really have to do some homework cause then its costly to fixs
May 22, 2013 | Sony CDXGT40U - Cdx-gt40u Fm Mw Lw Cd Dsp...
How do I remove the radio from my car???
There are special keys designed just for car stereo removal that are metal and shaped like a letter "U".
You can get these keys / tools at your local parts store....
There is sometimes a bracket mounted inside the dashboard and there is a bolt coming from the back of the stereo and that bold is ran through a hole on the bracket and there is a nut or a cap on it to prevent theft....
There should be two holes on the front of the stereo on each side, you insert the two keys into those holes. You need to go under and up inside the dashboard where the stereo is and remove the theft nut or cap and once you have the nut / cap off, disconnect any plugs that are plugged into the stereo, then you push both of the keys outwards left and right and gently pull the stereo unit out....
This is the best way that I can explain it...
I hope this helps you......
May 14, 2013 | Cars & Trucks
How to remove a deh 21001b from a vt commodore
He may have to get underneath the dashboard and see if their is a security strap or wire harness holding the radio into the mounting sleeve. It's common for installers to strap down the stereo to prevent thefts and other installer from easily taking the radio out. Have him keep trying.
Nov 26, 2012 | Pioneer DEH-2100 CD Player
Rx8 2008-My battery was dead after being stored for 5 months. I did not not disconnect the battery (I know I should have). I had my battery jumped with my husband's car. As soon as I connected the cables...
You should have disconnected the battery and fully charged it before starting the car.
The low voltage may have damaged some of the electronic components in the alarm system.
Charge the battery fully, then reconnect it and see if that helps.
Apr 16, 2011 | 2006 Mazda RX-8
How to remove 2001 hyndai sonata audio system
Instructions
Things You'll Need:
  • Screwdrivers
  • Wiring harness adaptor
  • Hyundai radio adaptor kit
  1. Open the coin holder and remove the two screws at the front. Pry the trim from around the gearshift lever and unhook the power wire to the cigarette lighter.
  2. Locate and remove the two screws from the bottom of the radio trim panel. Look for the screws, attached to a rod, below the glove box. Unhook the cable from the rod and pull the rod free.
  3. Place the shifter into "D" and slide the radio trim panel away from the dash. Locate the four screws at the front and sides of the stereo and remove them.
  4. Pull the stereo out of the Hyundai Sonata dash and disconnect the wires from the back of the unit. Connect the wiring harness adaptor to the original harness.
  5. Slide the new head unit into the Hyundai radio adaptor kit. Attach the wiring harness adaptor and antenna wire to the back of the new head unit and push the entire assembly into the dash.
  6. Secure the stereo in place with the four front and side screws and turn it on. Verify all of the speakers and features are working. Reattach the radio trim panel, insert the rod back into cable assembly and secure the trim around the gear shift.
In here you can find tips about remove radio...
- Hyundai Car Stereo removal
- Stereo Removal Hyundai (buy)
I really hope help you with this (remember rated this help). Good luck.
Oct 01, 2009 | 2001 Hyundai Sonata
How do you remove a stereo from a mercury topaz 92'
Go to a bad neighborhood and leave the windows down. Assuming any of the car is left when you get back, the stereo should be gone. Actually, there should be four small screws in the front panel.
Aug 29, 2009 | 1993 Ford Tempo
Remove car stereo from Ford Expedition 2006
Yes, the front panel needs to be removed but it takes 2 minutes. There are two screws holding the panel on, look above the instrument cluster. Once you remove those, gently pry the panel loose with a small flathead.. there are probably 8 plastic clips that hold it on.
Once the panel is loose, you'll need to disconnect all the plugs from the back, like the headlight switch, Info Center, and AC/Heater controls. You'll probably also need to lower the tilt wheel all the way down and place the shifter all the way down as well. You should be able to work the panel out then.
The radio is then held in place with 2 - 4 screws.
Mar 23, 2009 | 2006 Ford Expedition
Car won't start - anti-theft light flashing
it sounds like the immobilizer is faulty. this will shut off the electrical feed to the starter motor. you will need to take it to a garage to get this fixed.
hope this helps.
Mar 18, 2009 | 1997 Pontiac Sunfire
Stereo theft
try this to see if the right wires are there it normally cost about 130 to get a professional to do it
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 25, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
