Question about Tomtom RIDER GPS Devices
I have got a tom tom rider version 2, when I switch it on the software program starts and it won't start as it should
  • 3 Answers
Reset the device.
Search for"reset" on this site, or find out how in your manual. This has worked for some.
Posted on Oct 25, 2010
I just purchased a Tom Tom XL 335 SE, but when you turn the volume up above 85% there is no sound. I exchanged the gps for a new one and the new one does the same thing. Any ideas for how I can get it to...
This was is a known bug to TomTom. The suggested solution is to update to the newest software version. The Download Page Here is where you can get the newest version.
(1) Ensure that you have the latest version of TomTom HOME installed
(2) Backup your navigation device by clicking Backup and restore in HOME
(3) Make sure you have enough space on your memory card or internal memory.
(4) Transfer your favourites to your new map
Downloading and installing your map
(5) Select your navigation device:
Before you disconnect
(6) If you have a speed camera subscription, install your TomTom speed cameras.
Select your new map
(7) If you have more than one map installed on your device, select the new map. On your navigation device, tap Manage maps in the Preferences menu and then tap Switch map.
Mar 12, 2011 | GPS
I have a Tom Tom One version 2.It suddenly started switching screen views without me touching the screen,then the following day simply wont switch on.The green charging light shows when its connected to...
Theory 1: I wonder if it is due to condensation? Try warming it for a while with a hair dryer.
Theory 2: The power supply chip/ battery has died and in the process caused noise which made the screen switch.
Have you tried connecting it to your computer?
Have look through the tomtom forums but sadly I think your only option is to undo it and do some measurements starting with the battery. It's worth disconnecting and reconnecting the battery to see what happens.
Not a fix but best I can do with no further info.
http://www.tomtomforums.com
http://www.pocketgpsworld.com
regards
Feb 01, 2011 | Tomtom RIDER GPS Devices
My tom tom rider 2 unit is not shuting off
Open the compartment on the bottom of your TOM TOM RIDER and bellow the memory card slot there is a small hole and with a needle insert on it and bingo the unit shuts-off.
Feb 07, 2010 | Tomtom RIDER 2nd Edition GPS
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
My tom tom rider cnt find my cardo scala headset even tho it is on, can you solve, thanx
i have the tom tom rider 2 its a great bit of kit but i disconnected the scala cardo headset for helmets so that i cold try a different bluetooth headset for use in a car and it didnt work i then tryed to recconect it to my tom tom and it cant find it when searching for it what do i do ? what have i done?
Aug 06, 2009 | Tomtom RIDER GPS Devices
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Re: my tomtom go 920 I have connected my tomtom My pc keeps telling me to go to your home support in order to reinstall the home programme. The reason is error 0: Process failed to start up correctly....
There was an old Tom Tom Home (1.5 I think) and it is now Tom Tom HOME 2. If the icon has a little inward-facing arrow on the left-hand, lower corner then it is only a shortcut and you can safely delete them. You can always start the program by using Start, All Programs, Tom Tom etc.
Create a Restore point so you can undo the following changes and call it something like 'Pre Tom Tom HOME 2 update'.
Go to this web page:
http://www.tomtom.com/services/service.php?id=16&tab=87
and download the Windows version of Tom Tom HOME 2 and install the software. Tell the installing software to remove the old version of Tom Tom HOME - you won't need that any more.
Start up Tom Tom HOME 2 from the new shortcut icon that will now be on your Desktop and it should work unless you have an addition problem with your PC.
If it all goes wrong Restore your computer back to the Restore point you created above and you are back to where you started before you did anything.
Peter
Jan 28, 2009 | Tomtom GO GPS Receiver
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
Ipaq Quick GPS connection file downloads
You may need to use the hard reset to make the quick gps connection working. but you will lost all ur program or data, including smart nav or tom tom. if you ready want to use the hard reset, remember to download smart nav or tomtom program. or you will end out no map in your system. good luck
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
Tomtom RIDER GPS Devices Logo
124 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
