Question about Toshiba Portege S100-S1133 Notebook
Screen Issues After a while the screen will turn different colors then on a reboot I see thin color lines going from top to bottom. Then I shut it down for a few hours then start up again and it works again.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sounds like your video card is starting to fail mite need to install a new one ,need to do assp or mite loose entire system. la la linda
Posted on Jun 02, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
Permanent vertical line down monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
It will change color with different colors and also if you push the screen at the top point. Don't play with pushing the screen too often as this may cause more to show up.
Sorry there isn't an easy fix to this.
Fran
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Thin red horizontal lines across screen
While looking at your TV, remove the bottom right speaker grill. There you will find a cover held by a couple of screws. Remove the screws and behind the cover you will find the "focus pack" which is a group of 6 adjustment screws. The top screws adjust (in order from left to right) the brightness of Red, Green and Blue.
What you will do preferably at night (or with the room dark) turn the top left adjustment screw (Red) all the way to the left and then gradually turn it to the right until the point you can see the retrace line and then turn it slightly to the left until the retrace line disappears. That's it! You can do this for all three colors - if need be. These do go out of adjustment every now and then. The 3 screws on the bottom are to focus the colors individually to minimize "bloom" on the screen. It's best to be in service mode on your TV when doing this OR open up the cabinet and cover (with something) the other 2 colors while you adjust the focus of the color you're adjusting.
Good Luck!
S
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Toshiba Portege S100-S1133 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
