Question about Sceptre X7G Komodo II 17 in. Flat Panel LCD Monitor
Hello, I need to download original or updated drivers for this monitor asap, X7G komodo II. Thank you in advance for your prompt attention to my urgent situation. Tim C.....after downloading service pack 3 for windows xp home edit., my monitor settings changed to 4 bit color & 640 x 480 resolution and Will Not change. My trouble shooting program indicated it had a generic driver install. need manufacture driver to resolve issue.
    Top Expert:
  • Sceptre Master
  • 25,277 Answers
You need to go to the manufacturers web site and if available download the correct drivers.
Posted on Jul 04, 2017
5 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: Screen Resolution stuck at 640 by 480
you first install the audio drivers if the problem persists then attach AGP card then increase resolution and pc will ask question do you want to keep these settings say yes then you can see 1280x1024
Posted on Nov 27, 2008
bordiavineet
  • 50 Answers
SOURCE: ccannot change display setting to 640* 480
install vga (display) driver.
Posted on Apr 23, 2010
  • 670 Answers
SOURCE: Sceptre Monitor P/N X7G-Komodo II
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Posted on Oct 05, 2010
budmrtn
  • 11361 Answers
SOURCE: Sceptre X7G komodo II Power
Look for bad caps with domed tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/SCEPTRE/Sceptre%20X7G/
should repalce the caps in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 25, 2011
I have downloaded the driver but I cannot update it. I had to reinstall windows xp and the everything has gone back to original settings.
Right click my computer ,go to properties ,then click hardware tab ,then go to device manager when device manager opens ,on the right pane u will find monitor listed on clicking the + mark you will find Plug & play monitor listed, right click on the monitor ,you will get a option update driver ,then locate the driver files,&that's it.
Apr 20, 2013 | Dell E173FP 17" LCD Monitor
Sceptre X7G komodo II Power light and screen flash about every second. Could it be the blanking circuit?
Apr 24, 2011 | Sceptre X7G Komodo II 17 in. Flat Panel...
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
X7 G-NAGA VI POWER SUPPLY Transistors
do an advanced search on ebay for seller techtronsaver he should be able to supply you with the parts you need
Jun 04, 2010 | Sceptre 17" LCD Monitor
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
IMAGE DISAPPEARED... NOW IT TRYS BUT IMAGE WON'T APPEAR
there is a possibility of loose connection check all its connector cords
Apr 21, 2009 | Computers & Internet
The installer drivers of my toshiba laptop was gone and when my laptop affected by viruses i reformat it because I can't continue to unfortunately when i needed a sound from the speakers of my laptop there...
Hello MG_bhe,
Yup, you definitley need the drivers. Here is a link you can go to and purchase the original restore disc. All you have to do is find your model (they do list Toshiba). http://www.restoredisks.com/
Also here is a link to the Toshiba Driver download page, just have to pick your model.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Here is a link to a free software for Toshib'a that will automatically update your drivers for you.
http://www.driversupdated.com/exact/toshiba.php
Nov 23, 2008 | Computers & Internet
Sceptre X7G Komodo II 17 in. Flat Panel LCD Monitor Logo
55 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
