Question about Vivitar ViviCam 4345 Digital Camera
After I transferred the pictures to my PC, I get a 'CARD LOCKED' message. This has never happened before and I've had my camera for years!!?? It won't let me do anything at all, and I will really appreciate some help. Regards Bibi
  • 321 Answers
Hi have you try to removed the mem card out off the camrea and look on the mem card for a small slide button and moved to the unlock position if not its could be the mem card its self or
the mem socket inside off the camera..
hope that will help you
regards Alan..
Posted on Oct 13, 2010
Testimonial: "I did not know about the slide button!! That did the trick. Silly me... I am so pleased and I owe you a big THANK YOU Alan! :-D Bibi"
Samsung PL50 with Samsung 2GB memory card says 'memory full' even though I've cleared down the memory via my laptop.
Have you actually formatted the card in the camera ? Just copying the photos does not remove them from the card
Jul 15, 2017 | Samsung SL202 / PL50 Digital Camera
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Hello!Yesterday i was taking picture of nature with my Olympus camera,after that i transfered them onto my computer using usb cable.Today i can't take any picture because it says on screen...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
May 24, 2011 | Olympus FE-20 Digital Camera
Transferring images
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )
Jul 31, 2010 | Sharp VE-CG40U Digital Camera
My camera won't let me take a picture as message says Card locked How do i unlock it?/ I have had this camera several years and never happened before.
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional troubleshooting tips for this problem.
May 01, 2010 | Canon PowerShot A530 Digital Camera
Card Lock, when the card is not locked.
Solution,
Wrap the Camera with the purchese receipt, and bring it to the store you bought it from. They will send it back to Canon to be fixed. Hopefully it happened within a year from the purchesing date, so you will be fully covered by the manufacure warranty.
Good luck.
Dec 03, 2008 | Canon PowerShot A75 Digital Camera
Memory Card locked
Locked should not keep you from getting the data of of it, so one option is to transfer the pictures from it to your own computer then reformat the card (use the camera menu to do this, not your PC).
Another is to mount the volume on your PC and change the permissions on that device, including all sub-folders, so that it is no longer protected/locked.
Good luck.
DigiChick
Jun 09, 2008 | HP Photosmart M527 Digital Camera
Memory card error
Try another card. The card can have a life limit, after all it is flash memory.
Also try to use the card in a card reader, not the camera. If that works, and you can save your pics... (remember never try to delete or change any of the pics. on the card from the computer, a lot better chance of corrupting the files...that may be due to the fact that the camera and the computer can be seeing different ways of making folders and reading them...just mention that because I had it happen... always format and delete all pics in only the camera you use that card in.)
If you are successful to transfer your pictures, then format the card in the camera, and see if it will work.
The final on this is that if the card will not format, and will not save pictures, then it is finished. You can try to use it in another kind of camera, sometimes that may work as well.
May 18, 2008 | Nikon COOLPIX L3 Digital Camera
Transfering pictures from my memory card
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
This should solve your problem.
Mike @ compurepair.
Mar 14, 2008 | Cameras
Vivitar ViviCam 4345 Digital Camera Logo
49 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
