Question about Cameras
I have a sony ccd-trv64e pal camcorder, not used for many years, but kept in it's camera case.Attached it to it's AC>dc convertor but green light shows only for a moment on the convertor then fades out. The same convertor is currently charging a battery. When last attempted to use this cam corder to check tapes the edit search strip on top of the camera did not function. Apart from the obvious that it has had it's day does anyone have an idea how to bring this back to life for my film studies daughter? Many thanks, Gary
  • Cameras Master
  • 5,412 Answers
Battery is dead - replace it
Posted on May 12, 2017
  • 217 Answers
SOURCE: cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 15, 2007
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Posted on Feb 03, 2008
  • 317 Answers
SOURCE: Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Posted on Feb 05, 2008
SOURCE: purple and green digital lines across film
The heads are dirty. Run a self cleaning tape through if for about 20 seconds and that should fix it right up!!
Posted on Feb 26, 2008
SOURCE: Sony DSC H-5 Camera battery problem and slow response time
use lithium batteries. They last longer
Posted on Oct 20, 2008
Can CCD-TRV21 play PAL format?
This camcorder is an NTSC system-based camcorder. If you want to view the playback
picture on a TV, it must be an NTSC system based TV or a PAL M system-based TV
with an NTSC/PAL M transcoder.
Jul 07, 2017 | Video Cameras
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
How many mega pixels is the sony CCD-TRV228E HI8 CAMCORDER PAL NIGHTSHOT
It is 380K gross pixels / 230K effective pixels CCD. If you want to view the full specifications of the Sony CCD-TRV228E Hi-8 Analog Camcorder, you can go here.
Apr 07, 2011 | Sony CCD-TRV228E Camcorder
I would like to purchase a replacement operating instruction manual for: VCR Hi8 Model number CCD-TRV228 E PAL (Sony Product)
Hi Kenneth.
Don't pay for the manual, go here to Sony support and download the manual for free >>>>>>
Thanks for choosing FixYa!!
Jun 11, 2009 | Sony Cameras
Sony handycam and pc transfer
Sony CCD-TRV218E is analog PAL camcorder and can not be hooked with PC directly.
Computer (PC) requires digital format files to store on HDD and your camcorder has no digital file format to directly transfer in to computer.
You can hook your camcorder with DVD recorder to burn a DVD. Now you have digital files on DVD and can be transferred in PC.
Jan 21, 2009 | Sony Handycam CCD-TRV21 Camcorder
My Sony Handycam DCR-HC30E mini DV is not working
In many cases I found DC Jack defective in this model and resulted does not charge battery through ac charger nor power up directly with ac charger.
I would suggest to check ac charger and battery on similar model Sony camcorder and I think your camcorder has DC jack problem thats why camera is not getting power from ac charger.
Jan 08, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Error code c:31:23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Sep 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
How can I transfer video onto a PC
Your camera is Analog model, can't connected directly with PC. You need to install some sort of "Analog-to-Digital video convertor card" in PC to digitize its audio-video output.
Jun 19, 2008 | Sony Handycam CCD-TRV107E Camcorder
No display at all
these cam's are notorious for leaking capacitors time for a new cam
Jun 08, 2006 | Sony Handycam CCD-TRV57 Camcorder
Cameras Logo
79 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
