Question about Car Audio & Video
1996 Hyundai Accent - kids installed and then uninstalled a cd player, now there are blown fuses and the dash lights don't work. Any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Check to make sure you have no bare wires and then replace the fuses.
Posted on Oct 13, 2010
Hyundai coup electrical problem
Have you tried checking the fuse box for a blown fuse the cover generally has a picture of fuses and tells you what fuses are for
Jun 22, 2013 | 2000 Hyundai Accent - Coupe, with spoiler...
I have a 1996 hundui accent my friend replaced mt transmission and now my head lights wont work. i looked a ground wire from battery to transmission and its tight so any ideas?? also running lights work...
Could be Headlight relay, bad ground, bulbs blown, fuse blown or unplugged connector under the hood. The interior headlight switch is a long shot. Make sure everything under the hood is hooked up. Look around the firewall or headlights for unplugged connectors.
Sep 20, 2011 | Hyundai Accent Cars & Trucks
I have a 1996 ford explorer, the person who had it before had someone install an aftermarket cd player in it and now the door speakers nor the rear speakers work anymore, also the dash lights no longer...
Look for inst. lites fuse and clean the connectors at the fuse panel. The stereo speakers might have come loose from a poor wiring job. Look under the dash below the radio. Sometimes the dash light switch gets worn and doesn't work until you mess with it a little.
Mar 15, 2011 | 1996 Ford Explorer
I have a 2002 Hyundai Accent the Alternator went out and replaced that and it started just fine acept for the following: The low beams on the head lights work high beams ( but the low beams don't work )...
It sounds like a blown fuse. Are you checking them with a test light? And have you located all of the fuses. there will typically be a fuse box under the drivers dash area, and one under the hood. have another look Im certain you'll find a blown fuse. Good luck.
Jan 20, 2011 | 2002 Hyundai Accent
00 hyundai accent, wont start light on dash with
Could be as simple as a blown fuse for the ETACS module, but it sounds more like a problem with the anti theft immobilizer system. Does your car have remote keyless entry? And is the key you are using a factory key or one someone made? (factory key will be encased in bulky black plastic with hyundai logo) The transponder in the key might have worn out and is not talking to the car anymore. Some hyundais use the radio antenna to receive the signal, is there an antenna on the car? Is it hooked up? If it is a problem with the key and immobilizer system, It will unfortunately need towed to a dealer and reprogrammed.
Jan 19, 2010 | 2000 Hyundai Accent
My headlights wont turn on everything is good 1996 hyundai accent
the grounds may be bad they are behind headlamps but more than likely it is the switch
Aug 23, 2009 | 1996 Hyundai Accent
My CD Player wont turn on.
2007?... Might still be under warranty.
May 17, 2009 | 2002 Hyundai Accent
Cd player radio overhead light and trunk light not work
I can only answer this genericaly:
Check for a blown use at the auto's fuse box. Take care that there may be more than one location with fuses. If you call the dealer, most likely they can tell you right away where the fuse is located.
In many cars they are using electronic modules to control the lighting and etc. If this is the case with your model of car, it is possible that the electronic control module may have to be changed.
Jerry G.
Oct 27, 2008 | 2002 Hyundai Accent
Radio, cd player, overhead light, trunk light not work
ist definitly a blown fuse/circut breaker. take test light connected to a good ground recheck both sides of all fuses. be sure to turn dome light on when checking/ also check under hood for another fuse panel,also in glove box,and lh kick panel.
Oct 27, 2008 | 2000 Hyundai Accent
Problems with 91 Corsica Dashlight. Need Help!
Sounds like a wiring over load try rerouting the wires for cd player by running the hot wire to the battery and relocate the ground wire make sure the ire has enough amps and theres a inline fuse.
Jun 28, 2008 | 1991 Chevrolet Corsica
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
