Question about Hardware & Accessories
I have a EJ351 wall timer How do I set it for the whole year to come on at the same time. Do I have to set it for each day. If so that is impossible.
The EJ351 is a 24-hour repeat timer
Once you set the timer, the program repeats each day.
Here is the Intermatic page for more information
Posted on Oct 14, 2010
The red indicator light for the intermatic light timer EJ351 does not even go on - what can I do?
Hello Barb.
EJ351 timer indicator light problem:
Reset timer and try again.
This timer is rated for incandescent lighting only, 500 watt max, 40 watt minimum, and timer has two wires.
When replacing switch, either wire can connect to timer wires.
Check circuit breaker: click breaker all the way off, and then back on.
Use non-contact voltage tester to see if wires are live at timer.
If the timer does not work, then it has 1 year limited warranty for defects in workmanship.
Copy following link for EJ351 timer manual with instructions for resetting timer.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Jul 18, 2012 | Intermatic Programmable 24 Wall Switch...
I had a timer model EJ341C many years ago, it was broken down. I went a store and the salesman said the new model EJ351C is the substitute. My questions to you is (1) Are these two models pretty much the...
Hi Henry,
Intermatic EJ351 is sold today to replace earlier models.
EJ351 is very popular 24-hour ez-set timer with simple wiring.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Connect wires inside box to either timer wire.
Red indicator light is helpful when setting timer program.
Add a comment if instructions are confusing, and say what part of manual does not make sense.
Apr 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Timer has worked in the past as programed. However, upon resetting timer to correct time of day then setting "ON" & "OFF" porch light seems to come "ON" two hours...
I test timers.
Timers go bad.
EJ351 has 1 year limited warranty.
Wiring is correct or timer would not operate.
Bulb is good.
I would reset timer again and re-program.
If timer still will not function, then timer has gone bad.
Following page has manual:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Reset instructions: Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Intermatic Programmable 24 Wall Switch...
My EJ351 programmable timer has work perfectly since 2004. A few days ago the red light just started to continuously flash. I turn it off to rest and regrogram but no luck, the indicator light still...
What is amazing is that you know the year of purchase, AND remember how to set the timer.
1) Try turning off circuit breaker and see if timer resets.
2) Buy cheap circuit analyzer and plug into outlet on same breaker and see if line is clean.
3) EJ351 has limited 1 year warranty.
I test timers: usually when in-wall timer goes bad, it needs to be replaced.
There are no repair parts.
Google search: Intermatic EJ351 timer
Amazon sells EJ351
http://www.amazon.com/dp/B000Q9YUGU/ref=asc_df_B000Q9YUGU1408425?smid=ATVPDKIKX0DER&tag=nextagus0039178-20&linkCode=asn&creative=395093&creativeASIN=B000Q9YUGU
Aplus supply sells Ej351 timer.
http://www.aplussupply.com/intermatic/timer.htm
I buy timers from both these suppliers.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 28, 2011 | Intermatic Programmable 24 Wall Switch...
My intermatic switch won't turn off the outdoor lights. It covers the original light switch. It has a plastic cover with a extention that press smaller button underneath that says no op see inst. Please...
I answer questions for free.
I specialize in timers.
According to Intermatic, they no longer make the light switch timer.
I cannot find the instruction manual on Intermatic.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
From my experience, I suspect that the timer is old and does not function any more.
If this is not correct, add a comment and I will answer
Hammacher makes a wall switch timer. $40
http://www.hammacher.com/Product/78709?promo=Electronics-Safety-Security&catid=106
Intermatic also makes another timer that is simple to operate.
It is called the EJ351 but it has to be wired into the wall.
be3a610.jpgEJ351 cost $25 http://www.nextag.com/intermatic-timer-ej351/stores-html
Nov 01, 2010 | Hardware & Accessories
Hardware & Accessories Logo
150 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
