Question about Miele Novotronic W1918A Front Load Washer
I owna W844 Miele washing machine. Shortly after I have pressed the start button, the "spoolen" light starts blinking and the washing procedure doesnt continue. Do you know which the problem may be?
    Scholar:
  • 91 Answers
Hi dear.If the machine starts the cycle but does not start agitate there are two things could be wrong.1- Good thing loose motor connection,2- Bad one is control board gone.To checked the loose connection,take out the detergent drawer.There are 3 secrews,unsecrew them.Bottom left hand side where the filter lid open it.free the drain hose.Out of the front doorjust under the filter lid,there is one little clip holds the door.free the door & cheked the motor connection.If it's loose,make sure firmly attach the connection housing.put the machine back in order & start the machine.If machine takes the water in & still not rotate the drum(If the rinse "spoolen" light flashing),you need to call miele service centre where you are to get it replace the control board.I hope that helps.Thanks.
Posted on Nov 26, 2010
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
After pressing start programme light goes off and it 'bleeps' all the time
I had a somewhat similar problem on my Miele G896SCI dishwasher. Here was the fix that worked, provided by phone by Miele.
1. Turn on at On/Off button. 2. Press and hold Start/Stop button until the red light blinks. 3. Press On/Off button to Off, then back On.
That reset the machine and it returned to normal operation for years
Apr 09, 2011 | Miele 24 in. G686SCi Plus Built-in...
The check drain light on my Miele Novotronic W844 washing machine is flashing; I have drained water out from the drain pump/filter section behind the panel at the front then refilled water in the detergent...
Hi dear.Related to your explenation: It does have faulty pump but first checked the pump harness.That's important.If every thing seems OK then you can replace the pump.I hope that helps.Thanks.
Feb 13, 2011 | Washing Machines
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Mar 11, 2008 | Miele W864 Front Load Washer
Miele Novotronic W1918A Front Load Washer Logo
549 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
