Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Purchased a new ifonics 1206d amp and new subwoofer. had all installed professionally by local sound store. amp would go into protection shortly after leaving store. brought back and they told me amp or subs were "possibly" bad and wanted to chg 50.00 to check it. declined his offer. after few days, amp started cutting off...wiggled small 18g remote wire and amp would come on and off. brought it back to them, they restripped wire and reinstated it. worked for awhile, then stopped. now when remote wire is inside, the amp powers on, but no sound from sub. any sugg?
  • 11 Answers
SOURCE: Hifonics 1605d stopped working
the red light blinking because your amplifaier its dead look for the alimentation cabel end replace the calibration protector
Posted on Apr 16, 2007
  • 52 Answers
SOURCE: High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Posted on Apr 20, 2008
music head
SOURCE: problems with my txi 6006 amp
check all connections then check the subs voice coils to make sure there not burnt smelling, or burnt looking.then check the cars charging system you might have to add an extra battery,and or cap.
Posted on Jan 09, 2009
  • 77 Answers
SOURCE: sub making horrible thumping garbage sounds
you need an noise filter in line. It's been a few years since I've had a system but I had the same problem. High power amps like the one you have can actually pick up on the electric pulses from your ignition system. I think I got mine at walmart, or auto zone, somewhere like that. Their pretty cheap too. I don't remember how its hooked up, but If you know how to hook and amp up, this should be no problem.
Posted on Jun 23, 2009
  • 24 Answers
SOURCE: subwoofer popping noise
i had an amp do that a few years ago i did everything it turned out that it was the cdplayer. then agin myfriend had the problem and it was his altonator he had to get a ground loop isolator they are cheap
Posted on Feb 06, 2010
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Subwoofer popping noise
Feb 02, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Protect Light Coming On - BXi 1206D
If you actuate the subwoofer by hand, do you hear any scraping sounds?
It's possible the voice-coil is rubbing and tripping the amplifiers protection.
Try the amp on a different sub.
Jun 23, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Subwoofer problems
What started smoking the Sub or the amp?
Oct 08, 2007 | Car Audio & Video
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Jul 01, 2007 | Hifonics BX1500D Car Audio Amplifier
Protection Light irritation
If the amplifier goes into protect when there are no speaker wires connected to the amp, the amp is likely defective. The most likely culprit is shorted output transistors. If it's new, return it to the place of purchase for repair/replacement.
Sep 28, 2006 | Lanzar VIBE266 Car Audio Amplifier
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
