Question about Nintendo Wii Console
Put disc in set up game goes on for 1 or 2 minutes then error pops up on screen.
    Problem Solver:
  • 14 Answers
Yet another problem, that needs to be taken in, to a tech, and get repaired, many people dont understand,, these things are put together with rather cheap parts,, mother boards, circuts,, all cheaply mass produced,
Posted on Oct 13, 2010
After click on the game title. screen goes black
It is normal for the screen to go black for a couple of seconds once you click on the game title.
Although, for some games, the screen goes black for a longer period of time than other games. Another important factor that determines for how long the screen goes black is the health of your disc.
First of all, it is advised that you exercise patience and wait for a couple of minutes before trying anything. During this period of time, the game is trying to load all the necessary files required to run the game.
On the other hand, if the disc you are trying to play is not very clear or has scratches on its surface, this could make the game go on a black screen for longer than normal. So to prevent this from happening, make sure that the surface of our disc is very clean and is free from dust or scratches.
If you wait for about 5 minutes and it still doesn't work, then you can try ejecting the disc to see if it automatically quits the game and returns to the home screen. If it does, this means that the disc is probably bad and you are advised not to try loading it anymore as it could cause damage to your console.
Although you can try resetting the console if it still behaves this way before you confirm that the disc is bad. Below is the instruction oh how to do this.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hope this was helpful? Please comment for more information and thank you for using Fixya.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Im having problems with my playstation 3
error 8001050f this is a bug in the internal clock. just leave your ps3 off for 1-2 days then the problem will fix itself
Mar 03, 2010 | Sony Playstation 3 (PS3) Console
#80010087 error
if u downloadedthe game, it might be corrupted or have important files deleted when ripping the game, or if you have bought the game you shud check if its just that 1 game that dont work, or it may be your psp, check the case of the game if it requires a certain firmware.
Mar 27, 2009 | Sony PlayStation Portable (PSP) Console
Xbox 360 comes on dashboard pops up but wont go to the game
If you have uploaded the updates, this happens all the time. you must go to "my xbox" option and there will be a disc there. Hit "A" and it will play the disc.
Feb 24, 2009 | Microsoft Xbox 360 Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc unreadable
Dude mine does the same thing
What I do is pop off the front cover
find a black gear under DVD drawer and with game loaded move gear all the way to the left which engages drawer disc positioning to proper place for a "read" if I leave my disk partially raised it will scratch the disk!!!
This is what works for me-{out of warranty}
Sep 03, 2008 | Microsoft Xbox 360 Console
Error Screen
Playing Super Smash Bros. Brawl? Click here for specific help.
If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
    If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available
  • Jul 22, 2008 | Nintendo Wii Console
    Disc read error
    Sounds like a disk read error alright. Try replacing the laser eye device in the PS2. I know a good place with pretty low costing parts for PS2s. RichsPSXParts. If not the laser eye try the ribbon cable between the hard drive and the laser eye. Those I'd think be the most obvious first checks. I'm not 100% on it since every one I know whos PS2 does that wont let me look at it instead the throw it away. Such a waste.
    Apr 10, 2008 | Sony PlayStation 2 Slimline Console
    Playstation 1
    What you're seeing is the menu. You need to put the disc in the console, or the disc is dirty and will not play, so it then automatically goes to the menu.
    Mar 11, 2008 | Sony PlayStation (PS) Console
    Nintendo Wii Console Logo
    18 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
