Question about Kenmore Refrigerators
I have a Kenmore elite 52709100, ice maker is not working, checked trouble shooting water to the refrig water, checked controls, not working. Freezer works great. Ric
SOURCE: Kenmore Elite Fregirator
my kenmore freg.is not working but the light inside is on,also power indicator not showing useually its on no. 1-6 depend where you set up.
Posted on Mar 30, 2008
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
WCAnderson
  • 9 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Unfortunately, this is one of the inherent problems with a self defrosting freezer units. Some frost free models/brands are less smelly than others. Grabbing the cubes as soon as they drop so they don't sit in that nasty freezer air and placing them in a zip lock would help a lot but probably not completely. Be sure and clean the inside of the freezer often so there is less of the smell left in the plastic that surrounds the ice cubes as well as the foods. Don't eat freezer burned vanilla ice cream, for sure! Hope this helps.
Posted on Oct 11, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
2014 Kenmore side by side refrig. Water comes out of the door fine. Will not make ice.Tried the reset button on the left by the bucket, took top of door apart to see if mechanism was froze up.
Hello Rhonda Cornett,
Okay... water at the wall is connected... good...
but now you have TWO solenoids at the ENTRY POINT...
It would have been nice to know if there is water in the tray...
or if it EVER WORKED... but whatever.
If you are NOT getting water in the ICE TRAY...
you need to check that wire is connected to ITS OWN SOLENOID... (ELSE: solenoid might be bad)...
You might be able to TEMPORARILY REVERSE the water valves
to see if the door service still works with the SUSPECT VALVE..
Still works ... Ice maker trouble...
Fails solenoid trouble (bad valve) replace!
Then restore EVERYTHING... (take pictures ahead of tampering).
That click (or thump) you hear whenever you fill your water glass.
Every ice-maker I've ever tampered with has an on/off switch..
Fill controls... and firmness settings of some sort...
Check'em all out before getting DRASTIC.
Not the correct ICE MAKER PARTS
(illustrative purposes only)
appliance part houses (sears = pricy (IMLTHO)).
Water Filters Lawn Garden Appliance Parts
Jul 08, 2016 | Kenmore Refrigerators
Kenmore Model:106.56612500 side by side refrigerator ice maker not working .Possible water valve ,possible ice maker ,possible frozen water line .Ice maker is in the the freezer box not the door What is...
cheapest and up,, check for a frozen water line, defrost the entire unit, any of the components can be iced up, once defrosted,, if you still have a problem, then check the inlet valve ,
Jul 22, 2011 | Kenmore Side by Side Refrigerator
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker doesn't work.
TROUBLESHOOT THE ICEMAKER ON THE 54606300 SIDE BY SIDE REFRIGERATOR
May 02, 2009 | Kenmore 54603 / 54606 Side by Side...
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
112 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
