Question about Dishwashers
My dishwasher is not draining. I'ts flooding my kitchen
My dishwasher is flooding the kitchen. We are unable to locate that internal drain or disposal system to see if it's blocked. Please Help! water does not drain from tub but does not flood the kitchen and it sounds like the pump is running model # is GS0500L-02BA - I removed trap inside washer but was not plugged at that point - removed drain hose at sink and tried to blow clear but nothing happened.
  • pgalante Sep 14, 2008
    I have the same problem, it seems that that the flooding/leak happens near the end... please help
  • taziah Feb 06, 2009
    my dishwasher has standing water, i tried disconnecting it from the disposal(vacuumed out), tried pulling screen in machine and vacuumed(still won't drain)
SOURCE: Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Posted on Jan 19, 2009
  • 35 Answers
SOURCE: broken dishwasher
If there is no water in the dishwasher - i.e. it had finished a cycle, but now it is just the indicator lights that are on, then the chances are some water has got into the control system. It will probably dry out, given time. (maybe a number of days.)
If there is water in the dishwasher -i.e. it was part way through the cycle and stopped, it maybe that the outlet hose/pipe has got blocked - possibly by your plumber's efforts. Generally speaking, the fats are rinsed off by the hot water, but go solid further along the pipes, as it cools. It could be he has unblocked the sink drain side of things, but not the dishwasher drain pipe. Risking more water on the floor, if your flexible waste hose can be removed, pour some water down the waste pipe, see if it goes away fast enough.
One thing worth trying, if not done so, is to unplug it from the supply, and leave unplugged for 20 minutes or so. Then plug it in and see if it operates OK then. Maybe try that first.
Posted on Jan 16, 2008
rickzilla
  • 706 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Posted on Aug 26, 2008
leroyal
  • 2120 Answers
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Posted on Jan 06, 2009
SOURCE: main hose blocked so flooded dishwasher blockage
When this happens sometime the "Back Pressure" mucks up the sensor. It may have to be replaced?
Posted on Feb 12, 2010
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Dishwasher won't drain. Floods out onto the floor. How do I clear the drain, I have already cleaned out the filter
Hi
Thanks
Rylee
Nov 22, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a frigidare gallery ultra quiet III that is approximately 10 years old. It is not draining water to the point that it is leaking on the kitchen floor.
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Frigidaire Dishwashers
Water not draining kenmore dishwasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 20, 2009 | Electrolux Kenmore 24 in. Built-In...
Can i connect my Hoover HD73M Dishwasher to a cold feed?
First off, you need a hot water feed line for your dishwasher, not cold water
Secondly, if you have a garbage disposal installed on your sink you can connect the dishwasher drain hose to the side port on the garbage disposal. That's what that little port is for anyway. If you do have a garbage disposal and hook the dishwasher hose to it then make sure you take a hammer and screw driver and knock out the little plastic plug that's inside the garbage disposal port before hooking up the hose to it, if you don't you'll flood your kitchen.
If you don't have a garbage disposal on your sink, then you're going to have to replace a piece of your sink's drain piping with a wye (Y) tailpiece. The tailpiece has a small branch that comes off it to where you can connect the dishwasher drain hose.
Regardless of which way you hook up the drainage and water lines, make sure you test out the work you did by running the dishwasher and keeping an eye on it. I can't tell you the number of times i've seen people hook up stuff like this and not test it and then when they go to use the dishwasher it floods the kitchen..... usually when people are sleeping at night. Test your work.
Aug 01, 2009 | Hoover 24 in. HD73M Free-standing...
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Dishwasher does not drain completely, has standing water after every complete cycle.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. If you find suds in the dishwasher.
  • Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects.
    Please consult the Owner's Manual. Download a free copy of the Owners Manual and/or Installation Instructions. In the Installation Instructions, will be the procedure for removal of the drain plug. You may also check with the installer.
  • Be sure the kitchen sink drain is not clogged. The dishwasher typically drains into the kitchen sink drain or a garbage disposer. If the dishwasher drains into a garbage disposer, run the disposer to clear the drain system. Do not put hands into the garbage disposer. Serious injury could result. You should always turn on your garbage disposer prior to running the dishwasher to clean out any food or debris within the drain system.
  • Check drain hose where it connects below the sink for blockage or a kink in the hose. New dishwashers come with a white corrugated drain hose, which should be used. Re-using old, worn out drain hoses may promote kinking and blockage. If it is neccessary to extend the length of the corrugated drain hose, be sure the total length does not exceed 120 inches and the extention used is not kinked or crushed. See your dishwasher installation instructions for details.
  • Check the air gap if one is installed. It could be clogged. An air gap (not part of the dishwasher) is usually located on top of the sink. Some state or local plumbing codes require the use of an air gap between the built-in dishwasher and the drain system of the home. This plumbing device is used to prevent the possibility of back flow into the dishwasher in the event of a clogged drain system. This item is not a part of the dishwasher and, therefore, the dishwasher warranty does not cover costs related to cleaning or repairing a drain air gap.
  • Typical air gaps are easy to inspect and clean. Be sure the dishwasher latch is in the OFF position or unlatched prior to removal of the drain air gap cover. Simply lift off the cover (usually chrome, could plastic) and unscrew or unsnap (depending on type of air gap) the plastic cap below. Remove any material that may have accumulated and replace the plastic cap and chrome cover. This simple procedure should be followed any time the dishwasher fails to drain properly.
    View a short video about cleaning the air gap:
    Play Video
    Sometimes perceived "no drain" problems are not "no drain" problems at all, but back flow of water from the sink or some other device into the dishwasher:
  • If you notice dirty water building up over time in the bottom of the dishwasher and do not have an air gap, make sure you have a high drain loop. A high drain loop is created when the drain hose is makes a loop at least 18 inches above the floor. Usually this is accomplished by attaching the drain hose to the underside of the countertop. Without a high drain loop or air gap, dirty water from the sink can flow into the dishwasher. The high drain loop prevents back flow of water from the drain into the dishwasher if an air gap is not installed. View a short video about a high drain loop:
    Play Video
May 08, 2008 | Dishwashers
Dishwashers Logo
576 people viewed this question
Top Dishwashers Experts
