Question about ViewSonic Televison & Video
When the display monitor is turned on it immediately goes into power save mode.
  • 11,361 Answers
You need to check the power supply and the backlight inverter.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 13, 2010
Stop my lg flatron w2053tq monitor going immediately into power saving mode
How old is your monitor? You may have some bad capacitors. At any rate, you'll have to take the monitor to a Technician for troubleshooting. Good luck.
Feb 28, 2015 | LG Flatron W2053TQ
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
Dell monitor goes into power save mode immediately
The burners may have nothing at all to do with this. Try the monitor on another computer (a laptop will do) if you have one. If the problem perists with the monitor, then the moniitor has failed. If the monitor works on another computer, or you do not have another to try, then start the computer and tap the F-8 key to boot to safe mode. If that gets you a display, then fix the display settings, also check the device manager for any signs of hardware trouble, and make any corrections that may be needed, and reboot. If safe mode does not get you a display, try disconnecting the new hardware. If still no joy, I'd say it's the monitor.
Feb 20, 2010 | Dell UltraSharp 1707FP 17" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
THE COMPUTER IS IN A POWER SAVING MODE
I think you mean, your display is in power saving mode, this happens when there is no signal from the computer - the display then goes to powersaving mode, try restarting your computer, if it doesn't turn on the display. try the display on another computer to see if your display works.
if your display works with anohter computer, try it again on the problem machine, if its still in the power saving mode, then its not turning on, the computer is not turning on-
I would suggest to get a local friend or a tech to look into your computer and find the issue, if your handy with screwdrivers and know your way inside the computer, then you could take the case open and reseat the memory. try without any memory, then try with just one memory module. Then put them all back in, if this doesn't help, its not a memory related problem.
to save time i recommend you take the computer to a local professional.
Jul 15, 2009 | LG L1915S 19" LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Monitor cuts off
Hi...there,
In power saving mode to preventing futher damaged to the monitor. It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Nov 11, 2008 | LG Flatron L1750S 17" LCD Monitor
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
Televison & Video Logo
201 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
