Question about Canon imagePROGRAF iPF710 InkJet Plotter Printer
Using a canon ImagePROGRAF iPF710, reviewing the nozzle check pattern, it is clear that the cyan ink area has a line missing through it, is this a problem with the print head? I have done numerous print head cleaning (both type A & B) and still having the problem. Any ideas?
You propably must change the prind head. check the metters info, dont make a lot of prind head cleaning because you lose a lot of ink and you will rise the cost if you need to buy and printhead and inks
Posted on Mar 04, 2012
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
tigertail
  • 163 Answers
SOURCE: Black ink nozzle clogged
If you have tried 5 or 6 head cleans, left for about 10 hours and then tried 3 or 4 more without noticeable result then you probably need a head cleaning solution. Google for stockist near your area or try this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Hope this helps. Please take a moment to rate this solution, thanks.
Posted on Mar 25, 2009
  • 7 Answers
SOURCE: Unable to clean Epson C88 Nozzle
Hi,are the catridges genuine,if they're,head cleaning should remove the gaps unless the nozzles are clogged,theres a special solution for un-clogging in such cases.
Posted on Jul 01, 2009
komguy
  • 2306 Answers
SOURCE: MP830 Canon - NOZZLE CHECK does not print light cyan line
You will need a new printhead, QY6-0061-000, runs around $60.00 well worth it for your machine.
Posted on Sep 08, 2009
  • 43 Answers
SOURCE: We have been trying to print a map via the Canon
Shut off the device, pull the power plug. With the device un-plugged, push and hold the power button for about 5 seconds. Then you can re-connect the power and actually turn the device on. Now the issue you may be running into is the physical document you are trying to print is too large for the printers memory. You can fix this be scaling down the document, the steps to do that vary based on what application you are trying to print from, or you can increase the ram in your printer.
Posted on Feb 28, 2011
I have a mac. how do i set up so i can start printing
Go to Canon website put in your printer model number an get the drivers an software for mac! hope this helps !
Sep 26, 2016 | Canon 3811B007AA model imagePROGRAF...
I have replaced the print heads, and instead of printing red, which I made, it is printing black
DEAR FRIENDS; PLS DO THIS FIRST STEP FIRST
How to print nozzle check pattern iPF6100/iPF610/iPF710/iPF8000S/iPF9000S/iPF800/iPF9100
  1. Load unused paper.
  2. Press the Menu button to display MAIN MENU .
  3. Press or to select Test Print , and then press the button.
  4. Press or to select Nozzle Check , and then press the button.
  5. Press or to select Yes , and then press the OK button.The printer goes online and prints a test pattern.
Second later print out result pls compare you result print with my attachment picture.
replaced-print-heads-instead-printing-5j51azquscxy1hu2enwrxd50-4-1.jpg let say if anything color no same like example red = black,yellow = yellow black , cyan = dark or magenta = green.
this means got dirty on site purge unit and printhead unit. you need to call canon technician done services for you because i can't teach you how to clean the purge unit and print head unit scared you will spoil this both unit.
Hope can help you ,TQVM..
Apr 13, 2016 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Error 03800 500-280 C
Many nozzle on printhead did not inject .
You must clean your head or replace it. Or comes up in service mode
and check your nozzle check .For cleaning head you can take it out of printer and clean with head solvent, if not clears maybe u must replace print head.
Also check the canon ipf710 service manual from below link, it will save you money and time
Canon ipf710 service manual
http://goo.gl/e0h9OC
thanks
Nov 17, 2014 | Canon imagePROGRAF IPF710 Printer
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
When we print with out IPF710 with the print quality set on "high", it does just fine. But when we set the print quality to "standard" it prints parallel pink lines that are about an inch apart across the...
try to print a nozzle check from the test print menu and check if the 6 grids are correct.
From this print out you will find out if some of the colors are nto correct
Nov 12, 2009 | Canon imagePROGRAF IPF710 Printer
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
Banding as they call this and skiped print is probably caused by the the print head being PARTIALLY BLOCKED. Do a nozzle check and check the 4 colour matrix patterns that are printed out do NOT have ANY missing lines. Mine did till I used recovery fluid to soak the head over 2-3 days this cleared the problem completely.
Sep 11, 2009 | Office Equipment & Supplies
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
We have a Canon iPF700 plotter. Keeps flashing message about print heads needing cleaning which is not resolved by pressing cleaning button. Probably needs a service. Number of good engineer in our area...
First print a nozzlle check pattern. Check all colors. If the problem is in any other color than cyan then you can fix this issue. If not you'll have to replace the head with a new one.
Try to update the firmware also to version 1.32 (for iPF700) and 1.35 (for iPF710) and check the result.
Sep 10, 2008 | Canon imagePROGRAF IPF710 Printer
Canon imagePROGRAF iPF710 InkJet Plotter Printer Logo
801 people viewed this question
old marine
old marine
