To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
OOOOH NOOOO! You wasted your money sorry to say. The 2060 is an analog that is obsolete, a good majority of the parts in that machine are unavailable. I would cut your losses.
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer 1.) Left click Start in the bottom left hand corner of the screen 2.) Left click Control Panel 3.) Now, double-click "Devices and Printers" or "Printers and Faxes" 4.) In the Window you will see your printer, double-click your printer 5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Step 1: Toner Reset Menu
for Brother HL 3040CN and HL 3070CW
1. Open Cover where you can access toner cartridges
2. Press CANCEL & SECURE PRINT buttons at the same time and you'll see
the toner menus on the screen
3. Press + or - to navigate through to the toners you need to reset.
Note that each toner has 2 entries here, reset them both (STD means Standard,
STR means Starter)
4. The OK button will reset of the toners.
Dear,
your copier e-studio 350 some time showing '' dispose used toner'' It dont mean you install new toner... its mean you dispose used toner box.. Dear open the copier frant cover
and dispose used toner white box...
Thanks
Best Regards,
DEAR SIR; The H-4 code means heat unit not function property, but I can reset it for you just follow my steps;
1, press"#", "interupt", "c", "interupt" machine will go dead.
2, enter 14, then press start key.
3, press "clear" key to end of simulation.
now you can your machine back to work, if you need more help please email me, I'm always around but don't forget give me a rating, good luck, HAVE A HAPPY HOLIDAY !!!
