I replaced a lamp on a Zenith Projection LCD TV model # D52wlcd. The new bulb is working fine. However, the end of bulb life indicator light ( orange ) would not go off. Any advise on how to reset the timer to '0' would be greatly appreciated. The orange light is a bit annoying to see. Frazer
Resetting the lamp time
After pressing the "?" key on the remote control in Stand-By mode, press the "9876"
and press the "OK" button.
And then three LED in the front is stop after flashing for a moment.* Lamp Life Time Confirmation
1. Method1 : Enter ADJ mode with using the remote control. You can be confirmed
because " Lamp Life Time XX hr" is appeared.
2. Method2 : With using the remote control offered to consumer if you press the
menu button continuously, OSD menus will disappear then press the "9876" and
press the "OK" button to enter ADJ mode you can see "Lamp Life Time XX hr"
Posted on Oct 13, 2010
I got a 52" zenith
No,the tv message said replace lamp wright?Yes,mean the tv projection lamp is the causes and the problems.The tv projection lamp life span have ended that why the tv it is not holding a stable tv projection lamp picture.All throught these causes,does the tv make alot of clicking noises too,when the tv projection lamp is it on for 30 sec.and shut it self off?Yes,than the board that call the Ballast board it is also dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new tv projection lamp and a new Ballast board too for the replament too,if this tv causes have alot of clicking noises,when the tv is trying to ignite the tv projection lamp.
Aug 09, 2011 | Zenith D52WLCD 52" Rear Projection...
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
The little orange light next to the regular green light that appears when the tv is on is lit up....I suppose it has to do with bulb however the tv appears to work just fine...what does this light mean
Yes,the tv projection bulb life is ending.Sometime the LED light indication "LAMP"light up or blinkig,tv still work,because it just giving u a little advance warning that all.The "LAMP" LED indicaton light,light up right?
Sep 14, 2010 | Zenith Z52SZ80 TV
Zenith model D52wlcd projection TV has been saying replace lamp for several weeks. Has had a small pink spot in middle of screen. Now full screen is pink. is this a lamp problem or just DOA?
The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
Oct 07, 2009 | Zenith D52WLCD 52" Rear Projection...
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith d52wlcd 52 inch rear proj. overheating symbol appears within 2 hours of operation
some solutions
1 clean fan
2 lamp reaching end of life. replace
3 seak profetional help
Oct 04, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith model #m52w56lcd tv?
For a really good step by step with pictures guide to replace it go to
http://www.fixyourdlp.com/blog/?p=34
For a good place to purchase the lamp go to http://www.discount-merchant.com/Original-Zenith-Projection-LCD-TV-Replacement-Lamp-p
/zenith_m52w56lcd_lamp.htm
I have found they have the best price on these replacement lamps. You might also check Ebay.
Feb 21, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith D52WLCD 52 in.
if lamp replacement doesnt fix the problem then you are looking at a light engine
Aug 29, 2006 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
