Question about Zanussi Kitchen Ranges
Where can I find a wiring diagram for a Zanussi ZCE 7610 W Electric cooker?
4 Suggested Answers
SOURCE: zanussi cooker
thanks but solved the problem.The white wire was loose in the socket on wall.
Posted on Oct 15, 2008
SOURCE: zanussi zce 7690 main oven
Thought someone may find this helpful. We bought our Zanussi ZCG7690XN just 4 yrs ago. For nearly 2 yrs the main oven control stopped working. Never got round to replacing the timer controls- ~£80 or so. Read through some threads and thankfully found a few helpful. What I found difficult after accessing the control unit was recognising the correct wires to connect so as to isolate(over ride) the timer unit. Finally sorted this and presto it worked. The same process may help those who wish to replace their unit with a new one.
For those who will try, take safety precautions. If the spark generator works, there is likely power to the timer unit (and oven). If not check fuse, confirm mains supply.
The control unit is accessed first by unscrewing top oven front plates to gain enough room. Then with a flat screw or similar tool, take off the two small clock knobs and the two adjacent burner dials. you would then need to undo four little screws two on each of the burner dials. You can now gently extract the controls from below -can be tricky, (may or may not require using a plier to bend a bit of metal). With the unit out, turn it upside down and you would be looking at the rear of the circuit board with a blue wire, two brown wires connected to the relays and a red wire feeding back to the main oven dial(beside the spark generator). A green earthing is attached to the side . Leave this alone. All you need to do is to join the red wire to the nearby second brown(live)wire. I did this using connectors. Any other sensible means should be fine. The blue wiring returns to the light bulb and back with the others to electrics at the back. I took this off the timer as well.
I previously had recurrent problems with the grill spark unit connection- burnt off. Sorted this out by fixing the connection (access from the front top oven, unscrew a small metal protecting plate to reach it).
I do apologise if some find this too lengthy. Any questions are welcomed.
Posted on Dec 26, 2008
  • 10 Answers
SOURCE: my oven isn't getting hot
Most likely one of the elements in the lower oven. For this job you will require basic tools and a multimeter to check the individual elements resistance.
This Must be done with the oven isolated from the mains supply Before beginning work.
remove the screws holding the element in place carefully pull a few CM's of cable through the holes in the oven bulkhead and disconnect the element from the supply cables.
With the element out check for short circuit and breakdown from Mains supply to earth. Using the multimeter on resistance setting check between the terminals and the outer casing there should be no connection here at all. any lower than 2M ohms is asking for trouble.
Check the heating elements by probing onto either end of the element and reading the result back as an example a 230V 2500W element should read around 21 Ohms. Elements are not repairable internally.
Posted on Feb 21, 2009
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
How do I replace the thermostat switch on a Zanussi ZCE 7701CH? I have removed the screws for the side panels at the rear but cannot access the screws for the side panels at the front. The Product No...
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 18, 2011 | Zanussi ZCE7551X Electric Kitchen Range
Manual for zce 7550 bk ceramic top cooker
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 29, 2010 | Zanussi Microwave Ovens
I need to know the wiring diagram for the controls on zanussi zce 7700x. i just got a new thermostat which i need to put in but need to put the 2nd oven controls back right . thanks
Sorry to read about your problem, I hope this helps you out.
you dont need a wiring diagram, the part should be a direct replacement.. wire for wire..
if not you got the wrong part
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Oven fan
almost certainly a problem with the fan and motor. try moving fan blade with a small screwdrriver thro the holes in the back panel to see if it is jammed. after that you are faced with removing appliance, remove back panel and check motor continuity
Apr 21, 2007 | Zanussi ZHQ575 Electric Double Oven
Kitchen Ranges Logo
63 people viewed this question
Top Zanussi Kitchen Ranges Experts
ray gallant
Paul Bade
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
