Question about Symbol LS 4278 Barcode Scanner
LS4278 wireless scanner - paired with base OK. scanner is not populating NOTEPAD with barcode - Company headquarters is using one I sent them just fine - something locally at PC level is not transmitting the barcode through to the PC. USB is enabled, scanner fully powered, tried multiple ports - PC recognizes the device - I am at a loss why barcode not passing to PC - Ideas???
jackboy
  • 2985 Answers
SOURCE: LS2208 scanner unrecognized by my HP notebook
It is not likely VISTA will run your scanner software as it is very old. However you could check program compatibility mode and set it to run as Win 95/8 Check compatibility in Start/Programs/Accessories or go to my Computer Windows Help[ and type compatibility in the search field But I don't think you will get far.
Posted on Aug 06, 2007
SOURCE: Metrologic USB Voyager scanner
refer your scanner manual and scan the default barcode printed ,then scan the use interface barcode printed properly
Posted on Feb 02, 2008
  • 86 Answers
SOURCE: Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
http://tinyurl.com/359pwh
Your scanner might note be configured correctly.
here are the guides I downloaded:
http://tinyurl.com/2sakgf
http://tinyurl.com/33gh4g
And the MFG website where you can download the material:
http://www.metrologic.com/corporate/products/pos/ms9520/
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
Posted on Feb 14, 2008
SOURCE: no data is transmitted
you need software to convert to barcode to text. im in the same boat right now...keep lookin ;)
Posted on Jul 22, 2008
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Posted on Oct 07, 2008
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
HOW TO PROGRAM LS4278 SCANNER TO CONNECT TO KEYBOARD CABLE CONNECTION
Hi, i want to connect mt LS4278 with micrologix directly using the 8 pin ps2 port.
so any body can give me the pin configuration for making the cable RJ45 to 8 round pin.
pankaj
Jan 31, 2011 | Symbol LS 4278 Barcode Scanner
LS4278 scanner can't read digits
Hi, try scanning French Windows barcode from the USB section of the LS4278 Product Reference Guide. The barcode is on Adobe page 147 of 414. You may also have to scan the Enable Keypad Emulation barcode from Adobe page 150 of 414, but I would do this only after testing with the French Windows setting first. I suggest saving a copy of the document before printing the barcodes just to make it easier to print. Hopefully this will resolve the issue.
Oct 16, 2009 | Symbol LS 4278 Barcode Scanner - P/N...
How can you use a symbol model ls4278 with a usb converter for the ps/2 plug?
The scanner will probably give you error beeps because you are not using a PS/2 keyboard. All you should have to do is scan the IBM AT Notebook barcode from the LS4278 Product Reference Guide. The link below will take you to the manual and the barcode is on Adobe page 104 of 418. I would suggest saving a copy then printing just the page you need.
If the scanner does not start working immediately you should reboot your computer.
LS4278 PRG:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983403apdf&sliceId=&dialogID=116526806&stateId=0%200%2011869362
Jul 21, 2009 | Symbol LS4278 Handheld Barcode Scanner
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
LS4278 makes the same beep with a valid code vs an invalid code
Contact the Symbol Help-desk at 1-800-653-5350. What you are asking is not possible with the LS4278. What you are probably hearing at the grocery store is the cash register software generating an error beep. The LS4278 is really just a simple scanner( eben though it is cordless) but it has no memory, and therefore cannot be loaded with a database for error correction. That is being generated by the software at the store, not thye scanner itself. For clarification, uyou can call me at the office:
Bill Matisz,
qdata inc.
1-866-306-7226.
Jun 29, 2009 | Symbol LS2208 Handheld
Symbol LS 4278 Barcode Scanner Logo
125 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
