Question about Jandy Aqualink Rs4 One Touch Control System Control System
Cannot program my aqualink rs4 properly can someone walk me through step by step
    Top Expert:
  • Jandy Master
  • 5,075 Answers
Contact jandy they will send you a PDF of programming
Posted on Mar 05, 2016
  • 22 Answers
SOURCE: Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Posted on Dec 30, 2008
PartsCenter
  • 125 Answers
SOURCE: need instructions to run aqualink rs4
Here is a link to the manual for the RS4.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
SOURCE: AQUALINK RS4 REPAIR
The controller board in the outside power center is going bad. Unfortunately Jandy only provides a one year warranty for these. You will have to have the board replaced. We can help you in finding a replacement board and can halp you in replacing it as well. www.hydrotechpool.com. Hope this helps. Jamie Maroney, Vice President, Hydrotech Pools, Inc.
Posted on Mar 21, 2009
  • 61 Answers
SOURCE: my aqualink RS4 display is saying water sensor
The water sensor is just a thermometer. It is screwed into the pipe somewhere. It should be easy to spot as it is held on with a hose clamp. If the sensor is bad it will need to be replaced or you will not be able to use the heater. If you follow the wires all the way back to the control panel (up to where it screws into the board) you may find a break in it, which you will need to repair. The water sensor is just a resistor, so there is nothing special about the wiring - except it should be waterproof. If you cant find a break in it I would try to switch the air and water sensors. These should be connected on the control panel right next to each other, and are exactly the same. If this solves your problem then you have a bad sensor. With the bad sensor i would try to cut the wires about 3-4 inches from the probe and run new wire to see if there is a break in the wire that was not visible. Hope this helps.
Posted on Apr 09, 2009
Aqualink rs4 manual pdf
hit cancel after that shows up for each program that will get rid of them or you can write down all the information then hit clear memory and reprogram all you auxs
Aug 27, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
Aqualink rs4 owners manual
go to system set up then go to program highlight what you want to program then add start and stop time if to run all the time start 2:00am and stop 1:59 am it will shut off for 1 minute then restart
Jul 21, 2014 | Jandy Aqualink Rs4 One Touch Control...
Aqualinks rs4
Go to menu , program the pick pool and input your desired schedule.
Make sure the day and time is set correctly!
Program Group A is selected and the filter pump is programmed to start at 12 noon but does not turn on. If I start it manually, it runs fine and will turn off at the proper time. What could it be? ...
Check to see if your nine volt battery is good. The aqualink will hold it's programs but lose time and date. At that point it goes back to factory set. You have to have a fresh battery to avoid this.
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
My spa runs unscheduled various times of the day. How do I fix that?
You may have old programs set in your Aqualink and you will need to remove these. Your manuel can walk you through this.
Apr 25, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink rs4 when set on auto the system goes from filter to spa (the spa never having been programed).
Go through your menu again and reset. These have defaults that may be causing the trouble if the power went out or your battery backup is old. Check this and let me know and we can look further. Your menu should help to walk you through problems, it is very user friendly. Hope this helps, let me know.
Oct 25, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
69 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
