Question about ASUS A8N-SLI Motherboard
Keyboard stays on
Dear sir(s)
I just got vista 32 bits installed on a system with a asus a8n-sli motherboard. when powering down the system, the keyboard stays on and I have either to unplug the computer or the ps2 from the back to have it out. How can I fix this?
Thanks.
  • 458 Answers
I would first Reset the CMOS... do this by switching the jumper pin cap from 2-3 to 1-2 then give it power/and immediately power off.. then reset jumper cap position to original spot... the jumper can be located usually near the CMOS battery.
Posted on Jun 03, 2008
Power up issue resolved, A8N- SLI booted up in the main screen of BIOS, after entering the delete key nothing would happen. Tried numerous times, retarting still nothing. Cleared the cmos, nothing, tried...
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
hope this helps you
Sep 02, 2011 | ASUS A8N-SLI Motherboard
Added 1G memory, for a total of 2GB. the system still only sees 1G
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory. You can check below URLs for reference:
http://dlsvr.asus.com/pub/ASUS/mb/4GB_Rev1.pdf
hope this helps
Apr 18, 2011 | ASUS P5RD2-VM Motherboard
Is there a serial number on a the motherboard itself? I have asus A8N-SLI deluxe that is not putting out any display. And need S/N and dont have the box it came in.
You do not need the serial number to download the video driver, but you need the motherboard number, this is printed on the motherboard.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 16, 2010 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Recherche drivers asus a8n-sli premium compatible windows 7 pc qui date de 4 ans qui etait sous xp
From the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=nbulqxniNmzf0mH1
I see device-drivers for Windows Vista,
but I do *NOT* see device-drivers for Windows 7.
Try using the drivers for Windows Vista.
Jun 01, 2010 | ASUS A8N-SLI Premium Motherboard
Power supply not coming on
first of all you need to connected the power supply connector, processor connector, hdd connector, cd rom connector.
check it
Jan 21, 2009 | ASUS A8N-SLI Premium Motherboard
Asus a8n sli premium
From the Asus support site.
- Memory mapped I/O
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Asus a8n sli vista 32
Yellow icon means you have missing driver for the component.
goto the following link and search driver for your motherboard model no.
Try This
After finding the drivers for your mb, download the audio driver and install it, it will remove your yellow icon with actual component which you have...... enjoy..:))
Thanks
Iqbal
Mar 23, 2008 | ASUS A8N-SLI Motherboard
Once installed Asus A8N SLi will not boot up in Vista 64 bit
Link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Make sure that you have the lastest Firmware installed in your BIOS.
Also run Windows Vista Upgrade Wizard before installing Vista to check for compatability.
Note: Vote for me......
Jan 27, 2008 | ASUS A8N-SLI Motherboard
ASUS A8N-SLI Motherboard Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
