Question about Maytag Dishwasher
GE potscrubber 1120, there is residue left on the top of glasses on the top level
  • Maytag Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 27, 2011
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
GE potscrubber 940 isnt cleaning properly. Glasses cloudy, some dishes still dirty. Is there a filter that can be checked?
You need to add some vinegar. Depending on your water as much as 4-5 cups per load. I have had a Potscrubber for close to 10 years and discovered that they clean beautifully as long as you don't skip the vinegar.
Mar 01, 2011 | Dishwashers
I have been drinking Airborne lately and the residue is still on the glasses after dishwasher is done.Do I need a new washer?
heatman101
Dec 06, 2010 | GE WBSR3140DW Top Load Washer
GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Jan 21, 2010 | GE Dishwashers
GE Potscrubber 650 does not drain and top rack not washed
your not draining the washed dirty water out. its leaving crud on dishes. check drain pump and drain line for restrictions
Jun 22, 2009 | Dishwashers
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dirt and residue left on glasses
wash glases alone ad a jet dry aditive to detergant  Vitally
Jan 26, 2009 | GE Profile PDW8600J Built-in Dishwasher
Grit like residue after cycle finishes.
I had the same problem and it was fixed by switching dishwasher soap. We always used the same liquid soap for years and when this problem came out of the blue (about 8 months ago) I switched to Cascade action pacs with Dawn. It did the trick! No more residue since then. We now are having a problem with the dishwasher not draining (our unit is 8 years old), but the grit issue has been handled!
Aug 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Maytag Dishwasher Logo
502 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
