Question about Kenmore 19001
My kenmore will not turn on at all - Kenmore 19001
  • 6,993 Answers
your machine is not turning on because its having a power problem.
First, check the power cord, and make sure its intact and has no cut or disconnection. If the power cod is intact, then it means a fuse has blown on the power board or the power board maybe be defective as a result of power out-age.
Dismantle the machine, in order to gain access into the internal part of the machine, and check the fuse and power board.
But if you don't know about the machine repairs, I would suggest, you take it to a repairman to fix the problem for you so that you won't damage anything further.
Good luck.
Posted on Oct 13, 2010
How do I oil a Kenmore 385 sewing machine
Are these the pictures you have?
KENMORE 385 12612090 Owner Manual Oiling The Machine Oil The Underside
Something you can do is slightly wiggle the handwheel (do not turn it in reverse). The handwheel should always turn toward you.
Look at the pictures and watch where metal rubs on metal that might match the picture and apply one drop of fresh, good quality sewing machine oil.
Aug 04, 2016 | Kenmore Sewing Machines
How do I fix the wheel on my Kenmore sewing machine the belt is not broken but the wheel will not turn
Have you taken out the plate over the feed dogs, and cleaned it out and also cleaned out bobbin area. Some times thread gets jammed her, and stops te wheel from turning
Sep 09, 2014 | Kenmore Sewing Machines
Kenmore bobbin issues
try these suggestions
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Oct 25, 2012 | Kenmore Sewing Machines
Kenmore Sewing Machine 385.18221
Probably best to take it to a service technician.
Jun 12, 2017 | Kenmore Sewing Machines
My kenmore sewing maching model 15343 won't turn on. it worked perfectly last week, and now it won't turn on at all.
Check your connections, maybe it is only partially plugged in or if you have it plugged into a GFI plug in it may just need to be re-set
Aug 16, 2010 | Kenmore 15343
I HAVE A 117.959 KENMORE ROTARY SEWING MACHINE. CANNOT GET THE THREAD TO PICKUP FROM THE SHUTTLE. ALL PARTS ARE CLEAN AND IN WORKING ORDER. CAN SOMEONE HELP ME WITH THIS PROBLEM
I was having the same problem with mine when I first started using it. I hope the solution to your problem is as simple as mine. Turn the rotary wheel away from you instead of toward you. Most modern sewing machines (new singers etc.) the wheel turns toward you when you are sewing. However, with the pully system of the old kenmore, it will naturally turn away from you. Seems obvious, but if you are only used to working on newer machines you may not have thought of it.
Try it out. I haven't had the problem since.
Sep 14, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
60 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
