Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My 55 in sony hd projection tv after being on for a little while turns off green power light blinks and then turns off then repeats when turned back on
  • Willie Howell Oct 13, 2010
    what is the make or model of tv is it a sony or rca? sorry the sight tells me both.
  • sandymajor06 Oct 13, 2010
    sony kdf55wf655
    Sergeant:
  • 171 Answers
Did you replace the lamp already because if ou did and this is happening you have a BALLAST problem and you need to repalce this board
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Posted on Oct 13, 2010
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
55 in sony wega. green light blinks repeatedly and no picture. What could be the problem?
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 23, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Our Sony KDF-55XS955 turns off after 60 to 90 seconds, the green power button blinks about 30 steady blinks then turns itself back on, then repeats the turnoff, blinking 30 times, then turning back on. ...
That is a definitely a lamp issue - Get a NEW lamp (with casing) online, have it shipped overnight - install according to your user manual (this is a common mainenance issue) and you should be fine. Or just call Sony or go to their website and they'll ship it directly to your home. Best Regards,
Beach TV Repair
Treasure Coast, FL
Jul 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony wega 55'' tv screen goes blank including the sound and then comes back on a minute later. When the tv is first turned on the green light blinks 11 times
same thing is happening to me.....i chatted with a sony "expert" on sony's website he told me to use different inputs for the sources, im like listen pal, this is happening on hd channels also, where else can i plug the antenna? no response from the expert lol, but im still looking for an answer
Dec 23, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
