Question about Zenoah Toys
I have a Zenoah G62 that runs great but I can't get the idle slow enough. If I get it below 2300 rpms it will quit. I have had a kit put in the carb by a local shop and that didn't seem to help. I am running a 22x8 prop on a Sig Sundancer. The plane will slow down enough to get it on the ground but it will not slow down enough to turn. Is there anything other than carb adjustment that I should be looking for? Thanks Ron Ramer
emissionwiz
  • 80407 Answers
SOURCE: 1995 pontiac firebird formula v8 idle
The idle speed is not adjustable, it is computer (PCM) controlled, you can turn the screw for the hard stop, but the computer will just over ride that adjustment for the most part, what I think you may need to do is clean the throttle valve and the idle speed control air bypass valve, use carb spray, spray it in the intake with the engine running use the at least 1/2 the can, the engine will try to stall, keep it running, after you are done disconnect the battery for 10 minutes, reconnect and drive a few days so the computer (PCM) can relearn your driving habits and set the idle correctly based on your driving.
Posted on Oct 16, 2008
emissionwiz
  • 80407 Answers
SOURCE: low idle stalls out
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Posted on Mar 13, 2009
  • 3567 Answers
SOURCE: will not run
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw, (sticks out from side of carb perpendicular to the carb throat).
If you are smoking that badly, loose the gas in the tank and start fresh with a 32/1 gas/oil mix. That equals 4 ounces of TWO STROKE OIL to one gallon of gas. Do NOT use motor oil in the gas. It may continue to smoke for awhile, until it rids it'self of built up oil in the crankcase.
On the clutch, be sure the oil level in the gearbox is correct. This is where 10w40 motor oil goes. Check the clutch cable linkages. One at the clutch lever and possibly one at the motor. You should have about 1/4" play in the clutch handle before the lever starts actually pulling the clutch.
You can download a free PDF service manual from this site > >
http://www.carlsalter.com/motorcycle-manuals.asp I checked and your manual is on the list.
Please rate this solution. Thanks!
Posted on Apr 11, 2009
SOURCE: My 1993 chevy 1500 Silverado truck suddenly quits
I put a new fuel pump, fuel filter, and a fuel pump relay and the fuel pump is still not coming on. I am not getting any fuel. Can you please tell me what it might be.
Posted on May 02, 2009
  • 3567 Answers
SOURCE: Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
Posted on Jun 27, 2009
What is wrong wIth my Honda xr 125 idle?
have carb cleaned ethenol kills carbs
Mar 22, 2015 | 2005 Honda XR 125 L
Cutting out
Hi Thomas only thing I can think of is that its not getting enough air is it the right filter as it may be not be allowing enough air through. As you probably know if you don't get the right amount of fuel & air it won't run right. Hope it helps cheers Paul
Jan 23, 2014 | ATVs
2001 ford expler sport track. Wont go past 2300 RPMs
better take it to a local shop to get a digital readout of errors.....it could be transmission related
Apr 22, 2012 | 2001 Ford Explorer Sport Trac
I have a 1995 YZF 600. Its running a little rough but idles at about 2,500 rpms once the engine is warm, yet the engine still stalls out when the choke is not on. I have cleaned the carbs, and there in...
Hi, Cnester10 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Wont run without choke on full
YZF600R Forums View topic Bike won run if not choked
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 01, 2011 | 2002 Yamaha YZF 600 R thunder cat
I can't get my Fz750 to idle. Engine runs great above 2000 rpms. Will not run below 2000 rpms. Stalls. Have completely cleaned the carbs. Jets seem good. New Plugs. New fuel filter. Any ideas? Thanx
You need to sync the carbs after removing them it wont idle if they are out of sync.
When were the valve clearances last checked? It wont idle if they're out.
If you alter the valve clearances you shd sync the carbs after
Ride-Safe
Bike-Doc
Please mark this as helpful (if it has been!!)
Aug 14, 2009 | 1986 Yamaha FZ 750 AE (U.S.)
Mariner 25 hp 2 stroke hard to start then quits and won't restart
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
1995 chevy 4.3 idling at 2300 rpms
1995 S-10 Chevy Blazer just replaced fuel pump now it is idles at 1500 RPM's what should I do.
May 29, 2009 | 1995 Chevrolet S-10 CA Edition
I need a carb service kit for a KAMATSU ZENOAH G3K ENGINE.
I have searched high, and low, for ANY reference to the G3K, and it seems to be an orphan engine, in the US. However, here is a link to a parts supplier. I hope you can read Danish!
http://www.texas.dk/reservedele/trimmer-buskryddere/zenoah-komatsu/bc-341-fw-g3k/?drawingid=81
Does your engine have the Nikki slide valve carb, or is it a butterfly throttle?
Hope this helps...
Apr 03, 2009 | Garden
Outboard motor won't go - just serviced - not a car
make sure to check records for any e85 fuel been added to it e85 fuel smells like tekila or alcohool with water and is a fuel little be cheaper than e87
Jun 01, 2008 | 1988 Suzuki Samurai
Toys Logo
100 people viewed this question
Top Zenoah Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zenoah Toy Expert? Answer questions, earn points and help others
