Question about Toshiba e-STUDIO 282 Black and White Copier
Scan to email on a Toshiba MFP to an external address results in a mailbox unavailable error. Using an exchange 2010 server. Works fine internally
2 Suggested Answers
  • 13 Answers
SOURCE: Have Toshiba studio 450 &
why not just use the public scan folder if you search network places for the machine IP there is a folder there called scans which is a public folder so everyone can use it.
Posted on Sep 02, 2011
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
How to fix Database corruption
If you keep getting corruption, the most likely cause is bad hardware.
Hardware problems are probably responsible for 99% of all corruption issues.
Have you checked all of your hardware to make sure that it isn't the
culprit? As Teo suggested, have you ensured that you have the latest
firmware and drivers for all components? Does your server have a RAID
controller? If so, is it battery backed? If not, do you have write-caching
enabled? Suspect hardware here could be any one of hard drives, controller,
backplane, memory, etc. If it is a brand name server, make sure that you
get the latest diagnostics and run all tests on it.
If that doesn't get you anywhere, your best bet would be to open a case with
PSS - they should be able to help you identify what the cause of the
corruption is. The following KB article may also help you to find the
cause.Try this EDB Open File Tool http://www.edb.openfiletool.com/
Jan 30, 2015 | Microsoft Exchange Server for PC
Fix corupt messages exchange 2010 mailbox
I would say try moving users mailbox to see if that would help if not then no other option than to Restore from backup.
If doesn't help, look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/exchange-server/734-repair-exchange-priv1-pub1-edb
Or: Exchange Server Repair Kit is an absolute must-have for any software development professional working with MS SQL databases.
For more information: http://www.exchangeserver.repair/
Dec 21, 2014 | Microsoft Exchange Server for PC
Error to open EDB files of Exchange Server
You can easily recover your corrupt edb files with the help of this edb recovery Software which are available on http://www.edbrecoveryutility.com . It's quickly fix all issues of exchange edb files and you can open it without any problem.
Jun 12, 2014 | Microsoft Computers & Internet
How to recover emails of Exchange Server?
This utility easily solves all type of corruption issues of exchange files. For more information and free download click here:- Exchange Server Recovery
Jun 05, 2014 | Computers & Internet
How to recover damaged EDB file from Exchange Server
Affordable and effectively software for retrieving your deleted or damaged server files and convert it into PST format in simple ways.
For more information, you can go on this site :-Exchange Server Recovery
Apr 17, 2014 | Microsoft Office Outlook 2007: Windows
Mailbox store drop down list is empty in exchange
This utility easily solves all type of corruption issues of exchange files. For more information and free download click here:- Exchange EDB Recovery EDB to PST Converter
Feb 16, 2012 | Microsoft Computers & Internet
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
When using Groupwise migrator for exchange: following error "you do not have any outlook messaging profiles into which migrated mail and address book can be inserted. You must create one before you can...
Novell GroupWise to Exchange converter tool is just migration of Exchange server records. When you want to migrate Novell mailing server to Exchange server you required third party GroupWise to Exchange server. To know more about GroupWise to Exchange tool visit here: http://recoverydatatools.com/groupwise-to-exchange.html and read this post http://groupwisetoexchangeconverter.blogspot.com
Feb 18, 2010 | Quest Software GroupWise Migrator for...
Toshiba e-STUDIO 282 Black and White Copier Logo
756 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
