Question about Holmes Products HFH106 Heater
My holmes heater will not turn on, but the light comes on when the thermostat kob is turned to lo.. but the fan inside isnt working.. this happened out of nowhere
  • 26 Answers
Same problem, I took it apart and found that the thermostat had failed, there are "points" burnt out (like in older cars distributors) that make contact at the thermostat and there were some solder joints which had come loose as well, adding up to no contact through the "hot" side of the wiring. Basically it's not something you can repair, just go buy a new heater, they're about $30. If you decide to try to fix it, beware, it might be dangerous if you don't do everything exactly right, also beware that parts might cost more than the heater.
Posted on Dec 22, 2015
2 Suggested Answers
SOURCE: Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Thanks,
Posted on Mar 19, 2009
2002 jeep gr. cherokee laredo overheats only when sitting at an idle, temp comes back down when heater and fan are turned on full blast as long as jeep is moving
you electric fan probably isnt working with vehicle warmed up lift hood and watch temperature gauge when it starts to over heat check to see that fan is working if not it could be the fan relay or fan itself if the fan does turn on its most likley the thermostat
Aug 11, 2010 | 2002 Jeep Grand Cherokee
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Thanks,
Nov 22, 2008 | Holmes Products Holmes HFH5506-CN Heater...
Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Nov 21, 2008 | Goodman GMS90703BXA Heater
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
Holmes hrh314
the thermostat is doing what it is supposed to. it is reading the air around the heater and turns on - off the element. it's when it doesn't turn on the element is when to worry.
Nov 04, 2007 | Holmes Products HRH314 Baseboard Heater
Heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Oct 16, 2006 | Holmes Products HOLMES COMPACT OIL FILLED...
Holmes Products HFH106 Heater Logo
127 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
