Question about Philips 42PF9630A 42 in. Plasma Television
Dead 42" plasma - power problems
You info was very helpful however. I pulled the back of the TV off and checked the fuse at the AC input on the board. It did not beep on the multimeter. I am going to radio shack to find the fuse now - thanks a BUNCH
    Brigadier General:
  • 3,614 Answers
that was good to know.. good luc on your work..
`micro
Posted on Jun 02, 2008
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Red lin appeared on my vizio tv and now its not
is this dead set? if no power at all check first ac cord for the ac line from wall socket going to tv power ckt. or else we need to open back cover.
Mar 31, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Its dead no led on switch on and no picture
Yes it has a AC fuse you can check it but I have not seen one the was open. I think your problem is in the SMPS.
May 18, 2009 | Hitachi 42 in. Plasma TV
My dead 42" plasma - power problem
I have same issue with Samsung HP-S4253 Plasma. The fuse is a Littlefuse (manufacturer they do not sell), I have search and called over 20 places and the latest is Fuses Unlimited but it is discontinued and they do not stock but they can order. I will not be able to contact them until the holidays are over. There most likley is a minimum order. If there are other fuses you need write down part #'s so you can fill the minimum if required.
If there is anyone out there that can help with finding these hard to find fuses it would be appreciated.
There are most likey other Plasmas or TVs that use the same fuse just have to figure out witch ones they are.
Fuses on Power Supply Board: The 8 amp is the one I require.
T8AH250V P
T10AH250V
Break Down of Fuse Description:
T = Time Lag
8A = 8 Amp
H = High Breaking Capacity (Ceramic) 1500A @ 250V AC
250V = 250 Volts
P = RoSH Compliant
Aug 25, 2008 | Toshiba 50HP95 50 in. Plasma Television
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Atombomb72 - 42" dead plasma
This is the correct fuse:
see www.digikey.com
digikey part number is F2668-ND.
ESA 42" plasma tv not turning on
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Mar 16, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Aug 18, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
