Question about Whirlpool Washing Machines
Washer will not drain
We bought our Whirlpool Cabrio 12/24/06. It is our third washer that has had this problem!!! It will not drain!!! Any suggestions???
    Genius:
  • 1,028 Answers
Remove back lean washer forward remove the clamps on hoses and 3 screws holding the pump on left rear ..clean pump and reinstall
Posted on Jun 02, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My whirlpool cabrio washer has started shutting off half way through the wash cycle...won't drain and spin...could the motor be overheating or is there something else I can check?
Most likely the cycle timer needs to be replaced. it is basically a clockwork device that that has cogs attached to a spindle. if you check the schematics for your product you will find the part no. etc. any servicing of course needs to be done wit the power disconected
Jan 20, 2013 | Whirlpool WTW6400SW Cabrio Washer
Brown spots left on new CABRIO TOP LOAD WASHER bought at LOWES 27 days ago!!!!!!!!!!!!!!!!!!!!!!!
I have the same problems with the Cabrio washer. I hate this pair. I have always had Whirlpool appliances but after all the problems I have had with this set from day one I will never buy Whirlpool again.
Jun 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Get message LD. Won't drain. Removed clothes from washer but still won't go into drain mode.
Ur drain pump needs to be replaced. I just had this same issue with my whirlpool cabrio.LD means long drain.
Aug 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not drain or spin
http://www.fixya.com/support/r4604609-washing_machine_washes_but_wont_drain
Apr 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De
