Question about Philips 42PF9630A 42 in. Plasma Television
Problem not closed
I selected the FixYa by mistake. The TV power problem is still open
I am new on this web-site. I was hoping to rank or thank you for the suggestions and hit something that appeared to close the file. I didn't want to close it. Anyway, I got brave and opened the back of the TV. I got a friends multimeter and cheked connectivity on the fuse at the AC input on the board. Sure enough it was blown. I couldn't find a fuse today, I will head to a TV repair shop in the morning. I will let you know how things work. What could have caused the fuse to blow?
Posted on Jun 02, 2008
    Brigadier General:
  • 3,614 Answers
....? what happen?
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
Bought a 26 inch proscan from Costco on line. Tv won't turn on, led light is off as well. own TV approx 2 years wah can i do besides leave TV curbside?
Hi sglassgold,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated. I would advice also to replace the entire power supply for your convenience if finding technician there is not possible.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 14, 2011 | Proscan 26LB30H 26 in. LCD TV
No power
Hi Shane,
Here are some DIY steps that may help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live. 1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact, replaced if necessary. 3.Check the internal fuse - sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there some fatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is quite technical.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
Feb 06, 2011 | Sanyo DP42849 42 in. HDTV
My tv wont turn on at all
I'm assuming here that your outlet is live.
1. Check the power cord - check the cord it might be opened (no continuity).
2. Check the internal fuse - sometimes the fuse fail because of the power surge, replacing with new one will cure the problem. However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
3.If you see that the fuse is intact on the board, don't attempt to touch anything because there some fatal components stored electricity enough to hurt you with a simple mistake only.
JDVillanueva
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi, I have a Element 32" TV that is about 2 years old and the picture has gone out, sound is ok. When it is turned on the picture appears for a brief time (about a second) but not long enough for it to...
dpenn1, Do you have solder, soldering iron, solder wick, and a few basic electronic bench hand tools? Your monitor no different than lcd computer monitor in it's basic design technology and operation. Do some eading in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" (me) .. Open unit when you feel confident enough to not make mistakes!! Look closely at the switch-mode-power-supply section for the CLASSIC BAD CAPACITOR PROBLEM!!!!!! Let me know what you find. 12fixlouie
Aug 27, 2010 | Element Electronics Televison & Video
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
Canon ip2000 reset ink absorber
Waste Ink Counter Reset:
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanent
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
"After service mode Pls use software for permanent reset"
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Philips 42PF9630A 42 in. Plasma Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
