Question about Talon Campbell Hausfeld PowerDisc 200 Watt Power Inverter IB3003
No spark on talon tough tools 50cc anti-vibration chainsaw. changed plug but still no spark. what to do next
2 Suggested Answers
Editor925
  • 285 Answers
SOURCE: Talon electric chainsaw, what grade oil?
Hi there... Electric chainsaws only use bar and chain oil. If you go to a hardware store or garden power tool outlet, you will find bottles of bar/chain oil. That is all you need. Just fill the reservoir up and top up as needed. Any decent brand will work well.
Posted on Feb 17, 2010
What is theair gap setting poulan 2150 2.1c i
.025" or .6MM is the spark plug gap I assume air gap is what you were referring to is spark plug?
May 16, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Spark plug gap
The spark plug gap should be set to 0.5mm
Jul 23, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My chainsaw wont start.gas is coming out the muffler.i have changed the spark plug. what is the problem?
Sounds like a valve is messed up or a piece of carbon stuck in the exhaust valve that won't let close.Fairly easy to fix except the spring keepers a little tricky.You will have to remove head but there should be access to at least check the valves out. Thank you for using fix ya.
May 11, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Will start on choke and run 5 seconds. will not start unless on choke when i try to rev up it goes dead.
Clean or replace all fuel components.Change the spark plug or coil.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Ive replaced the fuel lines that have rotted out. but it doesnt run like it did before. what should i look for
Depend on for how long the saw has been used.When the time past over the head cylinder cloaks with heavy carbon sediments that avoid a proper spark gas mixture.
1-Try to change the spark plug.
2-Made a good gas oil mixture.
Oct 12, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
No spark on poulan 2055
1st try another good plug, if no spark, remove the pull start and you will see 2 small wires and 1 thick one going to the plug, disconect the one that has a spade conector on it (the other small one should be screwed down on to the coil) refit the starter and check for spark. if none replace the ignition coil/ module as one part.
Jul 01, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Carb problems
Pul the spark plug and inspect for fouling, replace or clean the plug and try again. The next step would be to make sure the carburator is not loose and is tight to the engine, then disconnect the fuel supply to the carb and verify it is getting fuel. This as a place to start your diagnosis, and proceed from there. It may require you to disassemble the carb and clean a blockage, but this is the extreme.
Feb 12, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My poulan pro 42cc will not start i get sparks from spark plug,but when i put the plug back in i get nothing
If you have spark and compression it must not be getting fuel.
Put a little mix directly into the carburetor and try to start it. If it pops and doesn't continue to run look at your fuel lines. I think you have a cracked hose. HTH
Lou
Sep 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have predator and wont start
Does it have good compression? Is the muffler plugged? Is the spark plug wet after trying to start? If not, try a little starting fluid in the plug hole, and try to start. If you get a few pops, try resetting the carburetor H and L jet screws each 1-1/2 turns out from CW stops. It should run with these settings. Warm the engine up, then apply full throttle and adjust H CW until it runs fast, but 4-stroking. It should smooth out when cutting. Next, set idle L for fairly smooth idle, yet follow the throttle without lag. Adjust idle speed just below chain movement. Hope this helps.
Sep 10, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Talon Campbell Hausfeld PowerDisc 200 Watt Power Inverter IB3003 Logo
Top Talon Electronics - Others Experts
Are you a Talon Electronics - Other Expert? Answer questions, earn points and help others
