Question about GE Dishwashers
Water does not pump out of dishwaher - GE Dishwashers
  • 310 Answers
Check the inlet of the dishwasher..............
Posted on Jun 01, 2008
  • GE Master
  • 13,433 Answers
Is there something stuck inside the water out pipe, or is there something blocking the water from geting out from the washer?
Dishwaher does not spray water during the wash or rinse cycle
Check m/c water pump. Look for clogged water ways inside the machine wash chamber. Check you water inflow to the machine also.
Apr 06, 2010 | Maytag 24 in. MDB5600A Jetclean II...
My dishwasher does not fill with water but if you add water as the washer cylces it works fine. What could be the cause of not releasing water into the dishwaher?
Sounds like pump has packed up,switch of electric and unplug open back of machine see if pump drive belt has come off or is damaged its quite a common fault
Sep 06, 2009 | Dishwashers
The dishwaher is going through the cycle but the macine is not washing. I checked the overflow float
filter might be choked (blocked) and because of this pump is not able to lift the water for gentle please check the filter and the pump head.
Jul 18, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Won't drain all the way, 1/2 gallon water left in tub
do you have the drain line going to an airgap? if not try making a high loop with the drain line to see if that solves your problem.
Mar 19, 2009 | Kenmore Dishwashers
The dishwaher dose not empty even with the pump running
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
Mar 01, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Does not drain water after wash/rinse cycles
check the drain pump at the button of the dishwaher.
its not a big job, but it is a pain to take it out.
once you have it out, take a look of the bland on the motor, make sure they are all there, missing bland will cause the water to bunce back and nto drain completely. take a look of the motor, it should turn freely. the pump is oneway. make sure nothing else is broken from the pump and the outlet.
if all failed, replace the pump.
Sep 04, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher fix
something has gotten passed the screen and is jamming your pump impeller pull lower spray arm pull screen and see if you can find what is jamming the impeller and remove it drain pump is separate
Dec 30, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
