Question about Sony CDX-3100 CD Changer
What do the 4 separate wires coloured ... blue/white , blue , black and red and yello joining to single yellow connect to on car loom please ?
the logos1
  • 8 Answers
SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
Posted on Apr 01, 2009
  • 27 Answers
SOURCE: hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Posted on Apr 22, 2009
SOURCE: Honda S2000 engine installed in kit car. How do I wire alternator
Unfortunately the Honda alternator is regulated by the ECU, which allows the ECU to intelligently reduce alternator engine loading to improve fuel consumption. The intelligent system uses an electrical load detector (ELD) located near the battery to control the alternator output voltage. A two wire alternator has an inbuilt regulator that will always generate the required charging voltage. When a battery is fully charged and the electrical loading is low there is no need for generating the charging voltage, in this situation the honda alternator will reduce the output voltage to reduce engine loading, hence improved fuel economy.
Posted on Jun 20, 2009
  • 10 Answers
SOURCE: need colour coding for wiring back of radio
black= ground
blue= antenna
red= power ingition
yellow= 12volt battery
blue\white= amp turn on
Posted on Jul 19, 2009
SOURCE: POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Posted on Aug 28, 2009
Wiring a d2 eberspacher diesel night heater up
how much it coast black & decker Heater product model no . or07d
thank you
Dec 22, 2013 | Heating & Cooling
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I need the wiring colour coding for the rear lights of a 2000 v40d as im fitting towbar electrics
Your post:
Hi There.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.
Good Luck
Apr 07, 2011 | 2000 Volvo V40
Need to know speaker wire colour config for 1994 4runner (toyota) as well as power and earth wires
A Right Front Speaker (+) Green Gray B Left Front Speaker (+) Pink White C +12 Volt Ignition Wire Gray Red A B C D K L D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow E Right Front Speaker (-) Blue Gray w/ Black Stripe E F G H I J M N O P F Left Front Speaker (-) Purple White w/ Black Stripe G Ground Wire Black Black H Power Antenna Wire 1 Blue (join wires 1 & 2 I Power Antenna Wire 2 together to this blue wire) AS VIEWED FROM MATING END OF CONNECTOR Do Not Use J K Right Rear Speaker (+) Red Purple L Left Rear Speaker (+) Black Green M Right Rear Speaker (-) White Purple w/ Black Stripe Do Not Use N Do Not Use O P Left Rear Speaker (-) Yellow Green w/ Black Stripe
May 29, 2010 | 1994 Toyota 4Runner
Fitting single towbar electrics, Hyundai Coupe 2.0 2004 (Tiburon)
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Apr 16, 2010 | 2003 Hyundai Tiburon
Hi. trying to re-install a pioneer deck where an alpine used to be. can't read the japanese on the alpine wiring to know which wire is for what. What coulour goes to the ignition, what colour is for the...
dnt get confused, follow these simple wiring .......
firstly cut off the old lug from the connected place, make sure you cut each wire seperatly....and you are going ti use the wiring agin, avoid making the wires shorter...
YELLOW..12V+ DIRECT FROM BATTERY...can be joined where alpine yellow was conected.
RED...12V+ IGNITION WIRE..can be joined where alpine red was connected
BLACK 12-, NEGATIVE....BODY GROUNDING
ALL SPEAKER WIRES HAVE +AND-, PURPLE/PURPLE----------WHITE /WHITE-------GREEN/GREEN.......GRAY/GRAY..ALL THESE ARE SPEAKER WIRES, COMPARE THE CONNECTION OF ALPINE AND FOLLOW THE COLOUR FROM APLINE LUG AND JOIN THE PIONEER LUG ....THEY HAVE BAISC COLOUR WIRE AND AHVE SAME TYPE CONNECTION..DO IT
Oct 30, 2009 | Alpine CDA-9851 CD Player
Need colour coding for wiring back of radio
black= ground
blue= antenna
red= power ingition
Jul 17, 2009 | Sony CDX-S2000 CD Player
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
pls rate people arnt rating hope this helps
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
Wiring
red ,,,positive acc
black .....ground,negitive
yello constint power ,,,memmory
blue white ,,,,,amp ,,,remote wire
Sep 07, 2008 | Kenwood KDC-319 CD Player
Fuse box
Wiring relays and connections – all modelsRelays (typical)
1 Vacant
2 Intake manifold preheating relay (carburettor models) or fuel
pump relay (injection models)
3 Seat belt warning system relay
4 Gearshift indicator control unit
5 Air conditioner relay
6 Dual tone horn relay
7 Relay for foglights and rear foglight
8 Relief relay for X contact
10 Intermittent wash/wipe relay
11 Rear window wiper relay
12 Turn signal flasher or trailer towing warning relay
13 Seat belt warning system (interlock) or rear window, driving
lights and oil pressure warning relay
14 Window lift or seat belt warning system relay
15 Headlight washer relay
16 Control unit for idling speed increase
17 Fuse for rear foglight
18 Control unit for coolant shortage indicator
19 Thermo fuse for window lifters
20 Switch unit for heated driver’s seat
21 Switch unit for heated passenger’s seat
22 Switch unit for overrun cut-off
23 Vacant
24 Vacant
Relays are symbolised as a number in a black box
Not all relays are fitted to all models
Connections
A Multi-pin connector (blue) for dash panel loom
B Multi-pin connector (red) for dash panel loom
C Multi-pin connector (yellow) for engine compartment loom left
D Multi-pin connector (white) for engine compartment loom right
E Multi-pin connector (black) for rear wiring loom
G Single connector
H Multi-pin connector (brown) for air conditioner or wiring loom
K Multi-pin connector (transparent) for seat belt warning system
loom
L Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (carburettor models) or
multi-pin connector (grey) for dual tone horn (injection models)
M Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (injection models)
N Single connector for separate fuse (manifold heater element)
P Single connector (terminal 30)
R Not in use
Fuse colours
Blue 5A
Green 30A
Red 10A
Yellow 20A
Jul 17, 2008 | 1987 Volkswagen Jetta
Car Audio & Video Logo
20 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
