Question about Copystar CS-1500 Copier
I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
Have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
Posted on Aug 11, 2011
Hello, I have an imagerunner 5000 and the screen control panel went blank but no error code. What do you think went wrong with the copier?
If the copier is still running properly despite the lcd screen being blank, you may have a burnt out power inverter board. If you look very closely at the screen and are able to make out very faint images or text, it is most likely a faulty inverter board. You can find these boards on ebay and should only run you about $50.00.
-David.
Oct 30, 2010 | Canon imageRUNNER 5000 Copier
HAD FOUR POWER SPIKES AND COPIER WENT OFF WITH A h
dude call a copier tech... and buy a powerline filter... this way the spikes wont affect your copier... the error is easy to fix... but you might have some damage under the hood... call a copier tech today...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 16, 2009 | Office Equipment & Supplies
Funcional problem code SC542
Hello sir; Follow the steps to reset;
1, press "clear mode", "107", then press and hold "clear/stop" key untill display change.
2, enter 5810, then press "execute" on screen, then press "close".
3, turn power off then back on, it will go back to normal.
Apr 28, 2009 | Ricoh Aficio 1018D Copier
I thank you for the help, I still have the problem, I have no Admin Password nor do I have an access code for a Toshiba e-studio 211c Copier, I did as sugested, neither passwords worked, then I went to 0 &...
O8 - 653 is the correct code for the administrator. Whatever number is displayed after entering 653 should be the admin password. Otherwise you can just enter a new password while still in 653 to overwrite the old one.
Mar 30, 2009 | Toshiba E-STUDIO 211C Copier
Konica 7165 Service code SC21-06
SC21-06 at power up.
Solution:
CAUSE: The transfer cleaning motor (M10) failed.
SOLUTION: To disable M10, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while pressing the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow three (2) times.
5. Verify that 3-0 is displayed. Use the right up/down arrows until 3-4 is displayed.
6. Touch the right up/down arrow one (1) time (3-4 will be displayed).
7. Touch [ON] (1).
8. Power the copier OFF/ON to exit the 25 mode.
9. Power the machine ON to see if SC21-06 occurs.
10. If SC21-06 does not occur, replace M10 (p/n56AA-3831).
good lock
Mar 13, 2009 | Office Equipment & Supplies
KONICA 3135 COPIER
This is a fuser abnormality code.To reset code:Holding down "2"&"5" while turning on copier.Press P-4-7-P on the key pad.(1,4,5,or 6 will be displayed on the copy quantity indicator).Press the 0 key to change the indication to a zero.Press the start/print key to inter the new data.Power the machine OFF the ON to exit the 25 mode.If the F code reoccurs after powering up the copier will need either a lamp or thermal fuse in the fuser unit.
Dec 09, 2008 | Office Equipment & Supplies
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Error code-6
open all case. power supply bored is seen.removable an 8 pin ic is seen. exchange ic from the one same ic besides the secondary memory ****. and transfer jumper lug downward.power on unit for 2 sec. return jumper lug up. power on unit. unit is now ok
Feb 23, 2008 | Kyocera KM-1505 Copier
HP Color Copier Error Code
Try turning off the device, and holding down the # and 6 keys simultaniously while turning the power back on. If that doesn't work reply back with the EXACT sequence of messages that display. I will continue to research the error code to provide a better solution.
Jan 01, 2008 | HP 290 Color Copier
Copystar CS-1500 Copier Logo
88 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
